Old 03-24-2014, 05:37 PM   #1
LuckyX2
LuckyX2's Avatar
LuckyX2 is an unknown quantity at this point
Tie Rods for Geomaster Knuckles
So I just put on some Geomaster knuckles on my s13 and the tie rods are not the correct length. Both are threaded in as far as they go but yet when the wheel is straight, only the passenger's side is straight and the driver's side is significantly toed in. It would appear that I need shorter tie rods or at the very least, a shorter one on the driver's side. Which are you supposed to use with these knuckles anyway?
By the way, this is with the offset spacers installed. Without the spacers, I had the opposite problem, the rods were too short.
My S13 SR Street Mod Build
LuckyX2 is offline   Reply With Quote
