#691 |
Thanks we aim to please! The Dynasty and Maxstar are a bit $$$$ but they are so small you can take them anywhere.... 200A is alot of power for most work.. The best part is they can run on 120 but we normally run 220. You can do 460 is your baller but it auto switches so you can change the plug depending on location. 220 welds smoother then a 120 outlet. Here is another weld on a RX7 manifold hehe, this manifold glows red often now at 450whp. This is a head flange weld (er rotor housing not head) and then a 2" runner where a 45 bend hits a 90.
Neukin Motor Development llc 399 River Bend CT Fort Wayne IN 46803 -->Neukin Store<-- -->DRIFT Clutch Store<-- |
#693 |
![]() Join Date: Dec 2002
Heres a titanium exhaust I welded.
I always feel like i just won the lotto and got with the hottest girl in school after welding titanium. Then I fabricated a stick of butter into a porcupine
#694 |
Wow. Neukin's stuff is sexy.
And Luke, you always bring the hotnezz. Nice. Just for materials, how much did that M3 exhaust run?
#696 |
Never welded Ti, seems it would be much like stainless?
Looks nice... is all that Ti or just the tube? Hard to find flanges in Ti i take it. That stuff is salty..i guess your paying to save 40% weight of a steel part. Hard enough to find weld flanges in 304 Thats a stick of butter at a SlimFast convention or something lol
#698 |
I thought I'd get off my lazy duff and upload some pics of some stuff that I did around here.
Here's a bracket I made for a dry sump oil tank. Wish I had a mill to make those holes. Wish I had a belt/disc sander even more ![]() A downpipe for an FD. The customer had gotten some kit that didn't fit worth a damn and was on a budget, so please excuse the scraps used on it. And here's some practice 304 stainless I used to set some of the settings on my machine. |
#703 |
A recent job i did today. been pretty busy with my car trying to get it done, but im never to busy for jobs like these.
welded up intercooler piping, brackets for the intercooler, blow off valve flange, and had to modify tabs for the radiators. The intercooler piping. customer taped it up for me and cut squares out for me to tack. All tacked up. All welded up. The brackets for the intercooler. Each radiator had one tab that needed to be modified to fit the car's going on. The blow of valve flange welded up (it will be welded to the pipe later on). ( the tubing was a little bit smaller in diameter from the bov hole, but that did not stop me.) In the end another happy customer. went to his house and everything fitted great. |
#704 |
![]() Join Date: Jan 2007
Hey guys just wanted to let you know the centerline intake manifold with the 90mm throttlebody does fit. Thank god I run solid mounts but I know that was a concern of most of you guys about fitment.
Heres a picture of it Ill try to take some shots of it in the engine bay. All i have to do now is make a nice bracket for the blaster ss coils which will sit either to the left of the rail or on top some what up in the air on that one.. Any ideas anyone ?? |
#706 |
Dis: Thats some baller ass tig work there.
TougeLabs: Thats a badass manifold. I have no idea on the coils though. I would have to see it on the car.
#707 |
Great work Dis!!
More info on that mani Joe (sorry!!1!one!)! Looks great, as long as it fits ![]()
Jordan Innovations has a new web site! www.JordanInnovations.com -- All your favorite FD Pro Drifters love it, trust me -- www.JordanInnovations.com Last edited by GSXRJJordan; 06-23-2008 at 02:07 PM.. |
#709 |
Fixed it, sorry!
The manifold looks like a much cheaper way to go than a Greddy IM, with potentially more tunability because you can change the stacks... does that even matter though with forced induction? I know on bikes changing the stacks makes a huge diff with how the bike breathes. And do they make a high-port version for the S13 head? I'd imagine it'd be easier to fit that huge plenum/throttle body/4" 90* elbow on a S13 head than the S14 head ![]() What kind of gains do you see on the dyno (and in what rpm range)? It seems like that design would have all 4 cylinders breathing evenly (so no lean condition on #4 like some manifolds), and give you a nice kick in the middle and top like SR's need... so someone could stay with small duration cams (to help spool up a big turbo) and yet throw that mani on and get a nice top end. <== *speculation/curiousity* And the all-mighty factor... how much $$$?
#710 |
Ok no idea about most of that. I know it would be more expensive then the Greddy.This has a lot of time behind it. We can do a high-port deff for a s13 the whole fitting factor is tight i may do some changes on it. Ill do an update when i can walk "Broken Calcanus " Heel..lol But yea the manifold is cool cause you can actually change the plenum tank so were going to dyno it with the centerline and the reg plenum style everyone else seems to run. The whole idea for this manifold was to run longer runners but space is an issue so I may do some changing around on the next manifold. Ill keep you guys updated though deff. And the fuel rails as well as the solid mounts are now finished.
Are you a jordan race team fan ? I used to work for Richie Alexander |
#711 |
![]() Join Date: Oct 2006
Dis: That;s some amazing work. Although some of the welds LOOK like they were a TINY bit dirty... Beautiful consistency otherwise.
Touge: Baller ass mani... that is all |
#712 |
![]() ![]() ![]() Also Tougelabs Solid motor and trans mounts are great ![]() ![]() ![]() Last edited by TougeLabs; 06-25-2008 at 12:14 AM.. Reason: cause im an idiot. |
#713 |
Atutt Thank you for saying baller thats exactly what it is....Ill keep you posted guys on my build up.
O the MSD is going to be mounted ontop of the fuel rail.no other options |
#714 |
![]() Join Date: Aug 2005
Hey guys im curious I want to ask before i blow 100$ to the trash. Can an intercooler core be cut in half and say make 2 intercoolers out of it. ofcourse new end tanks will be fabbed up along with it. but want ot know because i can't find the core size i want and i found the perfect intercooler to cut down the middle and make the FMIC set up for my Z32.
-Juan |
#715 |
B4 you go ahead and cut shit and what not check out Garrett they sell tons of cores. You can cut a core and make two but in all honesty I would try harder sourcing out the core you need.
What size core ? I will talk to Garrett if you want and see if they can do something for you. Let me know |
#716 | |
#718 | |
this may sound dumb, but what is it used for? assuming this isnt a mid/rear engine car. |
#719 |
![]() Join Date: Sep 2007
this thread makes me feel dumb and useless to society
![]() if only someone would employ me and teach me stuff like this, i was always interested in fabbing up stuff. great work here guys! keep the pics coming... |
#720 | |
Its for my S14. I wish i could find the picture of the Weld S14 to show you. ![]() |
