checking Fuel Pressure
Well, the problems I have been having lateley leave me and my mechanic to believe that my problem could be fuel related. He asked me to do a fuel pressure test to check it out.
So, I just wanna make sure im doing it right. -Unplug Fuel Pump Relay -Open gas cap -T clamp with press gauge -Install fuse back in and shut gas cap -Ignition "on" and read the gauge? I think it's right, just wanna make sure everything looks good before I possibly fuck something up. Thanks. |
![]() Join Date: Dec 2008
![]() Feedback Score: 15 reviews
Sounds right, it should build up the correct pressure (or not) then go from there.
I usually just get a towel and wrap it around the fuel line where im taking it apart. Pop it off and the fuel goes on the towel but guess the extra caution doesnt hurt. |
With the car running pull the fuel pump fuse and let the engine die out. Open the gas cap to relieve the pressure. T your gauge into the regulated fuel line. Put the fuse back in and then start it up.
#4 | |
![]() Join Date: Oct 2003
Just an FYI you will still have fuel leaking even with no pressure, be prepared. It'd be a good time to go to a Z32 fuel filter or at least replace your current one.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. |
went there, aint nothin man.
Only had one that read up to 10psi. they had like, tire gauges that went up to 100psi and wanted to try that, but the guy at autozone said it wouldn't work. |
autozone has them, but they are clueless. I picked one up from amazon.com cheap.
![]() Join Date: Jul 2007
Trader Rating: (106)
All you have to do is:
1- remove the fuel pump fuse and start the car to relieve the pressure (I usually just skip that step personally) 2- remove the fuel cap to relieve the pressure in the tank (this will prevent fuel from coming out of the fuel line once you remove it) 3- loosen the clamp on the hose coming out of the fuel filter (in the engine bay) 4- remove the hose that you just loosened the clamp on 5- use a t-fitting and a small piece of fuel hose to install the pressure guage 6- re-install the fuel pump fuser 7- start the car and read the pressure on the guage |
#16 | |
![]() Join Date: Dec 2002
They're the same.
i wanted to add, if you are looking for a fuel pressure gauge I bought one designed for schraeder valves and then a schrader to barb attachment. I can use the gauge for either set up now. I picked up a couple feet of hose as well...the stock setups are a bit short for our cars.
#22 |
all you need is a 1/4" block to double barbed fitting and any guage to duplicate this. It's a really easy setup to do. I never thought about just building one and leaving it inline.
I bought this: Amazon.com: Actron CP7818 Fuel Pressure Tester Kit: Automotive and then some of the parts at a napa for under $10 to make Amazon.com: Actron CP7838 Professional Fuel Pressure Tester: Automotive
