[HELP] Need part#or part name
![]() this is my s14(JDM) heater core bottom view need the part that goes between A and B Last edited by orioriori; 11-15-2015 at 06:06 PM.. |
![]() Join Date: May 2009
You likely will need to order the whole unit. IDK about the RHD S14, as I can't find a part number diagram. Though for the USDM S14 you cannot buy that whole unit anymore so you likely will need to just go find used parts if you want this to work again. You might be able to get a hold of a exporter in Japan who will send you the whole unit.
