![]() Join Date: Sep 2013
I'm in central Florida.
Please PM me with details on your swap. JZ+R154 preferred. Would like something turn-key or close to it I got a good amount of money to spend on a swap. Looking for a clean S13 chassis engine swap in Florida, no trashy swaps please. Thanks. Last edited by FLG; 05-04-2015 at 06:52 AM.. |
![]() Join Date: Jun 2007
Trader Rating: (31)
![]() ![]() ![]() ![]() Feedback Score: 31 reviews
I have a full 1jz vvti swap, with new stage three clutch and lightweight flywheel. Compression and leak down test performed and great! Asking 1675 for everything
![]() Join Date: Jun 2013
Send me your number I have a full rb25 swap I might sell ! Clean healthy !!! Running no smokes ! Strong !! Dm me your number I'm in florida so you can check it out in person running
![]() Join Date: Apr 2007
I'm a little further away, but I've got a non vvti 1JZ that's been re-sealed with an OEM gasket set (still have the rest of OEM gaskets), new water pump, timing belt, idler pulley, tensioner, new cam/front/rear mains, etc. Has Aristo 440s, Soarer harness/igniter, auto trans, r154, new jz bellhousing, Spec flywheel/clutch, Driftmotion t4 coated manifold, Precision t4 turbo.
Probably forgetting some stuff but the engine hasn't been run since the new stuff was put on it and the clutch/flywheel is still new in the box. I'm asking $3500 for all of it. |
| 1jz, 2jz, florida, rb25, s13 |
