![]() Join Date: Oct 2008
Trader Rating: (131)
CamryOnBronze Partout Wave 3: Engine
IF A PART IS NOT LISTED, IT IS NOT FOR SALE YET OR HAS BEEN SOLD.
Well guys, it’s been an awesome run for my S13. I’ve enjoyed every bit of this build over the last four years, but now that I have a family and I have grown a bit older, my life and priorities have changed. It sounds cliché and I never really thought it would happen to me, but I’ve decided that it is time to move on. I’ll be parting out the car in stages. Please do not ask me about a part that is not posted for sale here. If it is not listed here, it is currently not posted for sale or may have already been sold. The partout will be split into a few different phases/threads as I have the time to remove and document items. Most of the items listed below have already been removed, and if they haven't been, they will be within the next week. The actual engine and transmission will be posted for sale after these items have been sold in a week or two. 1.) PBM Cobra Downpipe: Powered by Max Cobra downpipe. Has the shaved divider for the S15 GT28 turbo and a bung welded on for a wideband O2 sensor. A plug is included if you choose not to use the bung. Downpipe is partially wrapped with Mishimoto exhaust wrap, and I will include the additional wrap and ties I have with the sale. Downpipe is in great condition and spent almost all of its life wrapped. ![]() ![]() ![]() ![]() $295 Shipped via UPS SOLD SOLD SOLD! 2.) Megan test pipe: Used with scrapes on the flanges, but still works just fine. Gaskets and hardware not included. ![]() $45 Shipped 3.) Tomei Turbo Manifold: This is the older version of the Tomei turbo manifold. The badge, like most of these manifolds, fell off before I purchased it. There was a crack where the runner closest to the firewall meets the flange that I had professionally TIG welded, and you can barely tell it was ever there. Makes the SR sound great! ![]() $375 Shipped via UPS SOLD SOLD SOLD! 4.) Tomei Coil Pack Cover S13: Gently used Tomei S13 coil pack cover. Includes hardware and original packaging. ![]() $100 Shipped via UPS SOLD SOLD SOLD! 5.) NISMO 555cc Side-Feed Injectors: I used these injectors for about 20k miles. Great condition and perfect for the fuel needs of the S15 GT28 turbo. Also fits the KA24. ![]() $450 Shipped via USPS 6.) GReddy Suction Kit: Allows you to run the S15 GT28 turbo and Z32 MAF on your SR20 without clocking adapters. Includes intake pipe, brand new air filter, and both turbo inlet/outlet pipes. This kit from GReddy no longer includes these pieces. Perfect for upgrading to S15 turbo! TURBO PIPES NOT PICTURED, BUT INCLUDED: ![]() $250 Shipped 7.) Z32 MAF: used Z32 MAF sensor. Screen is in excellent condition. Pigtail not included. ![]() $85 Shipped SOLD SOLD SOLD! 8.) S15 GT28R Turbo: S15 spec R turbo used for about 22k miles. Never abused or boosted past 15 PSI. Includes S15 oil drain, drain tube, and DIF braided turbo lines with the appropriate oil restrictor and fire sleeving installed, and HKS turbo actuator. I’ll throw in the gaskets (used) and locking tabs/nuts as well. This may seem overpriced, but please keep in mind that almost $400 in extras are included with the turbo. Feel free to make a reasonable offer. ![]() $875 Shipped via UPS 9.) GReddy Intercooler Kit: Includes intercooler core, lower cold pipe, and lower hot pipe. I was using a different cold pipe for my GReddy intake manifold that I sold with that, so I do not have a cold pipe. I do have a hot pip with BOV for sale separately below. I will include the black couplers I purchased, T-bolt clamps I added to the kit, and the original blue couplers as well. ![]() $375 Shipped via UPS 10.) GReddy BOV/Hot Pipe: GReddy hot pipe with flange and GReddy Type RZ blow off valve. Includes optional flange to recirculate the blow off valve if you choose to do so, and the original blow off valve box. Hot pipe has some scuffs, but is on OK condition overall. ![]() $315 Shipped via UPS 11.) GReddy Pulley Set: Discontinued GReddy pulley set for S13 SR20DET. Includes all three pulleys and necessary hardware for installation. Great condition. Also includes a like new Power Enterprise Alternator belt. ![]() ![]() $245 Shipped via USPS SOLD SOLD SOLD! 12.) GReddy Radiator: Used GReddy radiator. Includes OEM Nissan rubber mounting feet and GReddy mounting brackets. Has a ding in the side of it that was there when I got it, but does not leak and cools very effectively. Pretty cool piece for the engine bay. $900 new. ![]() ![]() $475 Shipped via UPS 13.) Samco Hoses: Black Samco radiator hoses. Includes T-bolt clamps I sourced for these. Good overall condition. ![]() $65 Shipped via USPS SOLD SOLD SOLD! 14.) Chase Bays Power Steering Kit: Power steering kit from Chase Bays. Includes lines, fittings, and reservoir. Despite the rumors, I never had a leak from this kit. Cleans up the engine bay really nicely! ![]() $205 Shipped SOLD SOLD SOLD! 15.) Chase Bays Clutch Line: Chase Bays clutch line. Allows you to remove the firewall line and clean up the bay a bit. $50 Shipped via USPS SOLD SOLD SOLD! 16.) NISMO Slave Cylinder: Used NISMO clutch slave cylinder in great condition. $125 Shipped via USPS SOLD SOLD SOLD! 17.) Cusco Engine Mounts: Cusco solid engine mounts. Never had an issue with these raising the engine or anything like that. For sure makes the cabin a little more bumpy, but it never bothered me too much for a street car. [Image coming soon. Here is an old image:] $185 Shipped SOLD SOLD SOLD! 18.) Hallman Boost Controller: Used black Hallman boost controller. Includes optional spring and mounting bracket. [Image coming soon] $55 Shipped via USPS 19.) NISMO Transmission Mount: NISMO transmission mount in great condition. Includes down pipe bracket and hardware (most S13s are missing this piece. Helps a ton with keeping the exhaust tucked up and solid.) [Image coming soon] $95 Shipped via USPS 20.) OEM SR20DET Clutch Fan & Shroud: Clutch fan in great condition. Includes shroud for SR20 as well, which can be pretty trick to find from time to time. They most effective method of cooling for the SR20 IMO. Clutch was recently rebuilt before I purchased it. ![]() $120 shipped via UPS (large box) 21.) Tomei Rocker Arm Stoppers: used for about 20k miles. Great condition. $45 Shipped via USPS SOLD SOLD SOLD! 22. Apexi Power FC L Jetro: Apexi Power FC standalone ECU for S13 SR20DET Blacktop with MAF setup. Includes Power Commander. Currently tuned for S15 turbo, 555cc injectors, Z32 MAF, Tomei poncams, etc. Excellent condition with original box included. Pretty hard to find these things in good condition these days, not to mention with a very usable tune on it. Dyno tuning cost me over $300. ![]() ![]() $890 Shipped via UPS w/ full insurance 23. New OEM S14/S15 SR Valve Cover: Brand new from Nissan with factory black wrinkle coat finish. Great as a replacement cover or to use to build a S13.4 valve cover, which was my original intention. I also have two Earl's -10 weld on fittings that I can include for an additional $15. ![]() $185 Shipped Please allow 1-2 weeks for delivery of these items. Most are removed from the vehicle and ready to go, but some will take me just a little bit of time to remove, effectively package, and ship. It has been crazy, but the partout has remained very organized and most items ship within a couple days of receiving payment at most. I appreciate everyone’s understanding with this! See my iTrader for any concerns about my integrity. I will ship items either UPS or USPS depending on the size of the item. Payment will be via cash in person or PayPal. Unfortunately, I will not be able to hold items for people or accept payments- cash is king. Not looking for trades at this time. PM me with any questions or concerns- thank you! Damon Last edited by CamryOnBronze; 11-02-2012 at 09:28 AM.. |
#10 | ||
Thank you sir!
Replied PM Sent! Quote:
Added a photo of when I got them. I have not removed them yet from the car, but they will be out and ready to ship by this weekend. I can provide a current photo then if needed, but they pretty much look the same. ---------------------------------------------------------------------- Item status has been updated. The following items sold overnight: NISMO Clutch Slave GReddy Pulley Set Bride FG Seat Rail (from previous thread) These items are pending payment: PBM downpipe Tomei Coil Pack Cover Tomei Rocker Arm Stoppers |
#22 |
This has been sold, sorry.
Final bump for this thread. Here is a list of what's sold and what is still available. All items sold will be shipped on Monday- thanks for the interest! SOLD: PBM Cobra Downpipe Tomei Turbo Manifold Tomei Coil Pack Cover Tomei Rocker Arm Stoppers Z32 MAF Sensor Chase Bays PS Kit Chase Bays Clutch Line Samco Hoses GReddy Pulley Set NISMO Slave Cylinder Cusco Motor Mounts STILL AVAILABLE: Megan Test Pipe NISMO 555cc Injectors S15 GT28R Turbo GReddy Intercooler GReddy hot pipe/RZ BOV GReddy Radiator Apexi Power FC NISMO Transmission Mount GReddy Suction Kit Hallman Boost Controller OEM Clutch Fan & Shroud New S14 OEM Valve Cover Shoot me a PM today if you have interest in any of the remaining items. I'm in a motivated mood and might be buying an Evo this weekend, so I might be able to cut some deals if I get payment before Monday morning. Thanks!Damon |
