Old 12-02-2009, 07:21 PM   #1
d0pe240
d0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of light
s13 lowering problems
im having trouble getting my s13 slammed. i want it to lay frame on the ground, but i dont know why my car will not allow me to slam it in the front, the rear is ok. i have own two sets of coils now, the first were cusco. i bought shorter springs for it (150mm vs 200mm)and removed 2 collars and maxed it out, that didnt help much, it made the tire even with the fender. sold the cusco's thinking they were the reason and bought some megan tracks since i heard they would lower alot. put the 150mm springs on and now im barely tucking the top of the tire treads. 1 collar removed with 150mm spring should lay some frame on megan tracks right? im thinking now that my car is the problem, but i dont know what is causing it. here are some pics of the megans and the shorter springs.
d0pe240 is offline   Reply With Quote
Old 12-02-2009, 07:46 PM   #2
singlecamcammed240
singlecamcammed240 is making his/her stupidity well-knownsinglecamcammed240 is making his/her stupidity well-knownsinglecamcammed240 is making his/her stupidity well-knownsinglecamcammed240 is making his/her stupidity well-known
could it be your front tension rods hitting your front swaybar?
singlecamcammed240 is offline   Reply With Quote
Old 12-02-2009, 09:06 PM   #3
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
What size tires and rims are you running, maybe they arnt big enought to tuck under the fender lol...
I had PBM coilovers and my car was slammed(frame about 1inch off ground) and i had 17's and they were tucked...
Ceepo is offline   Reply With Quote
Old 12-03-2009, 05:14 PM   #4
d0pe240
checked the tension rods and thats not the prob. still have space between it and the sway bar.
i running 17's all around with 45 sidewall.
the car drives pretty fine, i never got it aligned yet. anyone else? thanks for the replys so far.
Old 12-03-2009, 05:19 PM   #5
Ceepo
Ceepo's Avatar
what is the preload on your springs?
Old 12-03-2009, 05:22 PM   #6
SoSideways
SoSideways's Avatar
It looks like he preloaded the springs to the max and maxed the damper out to full extension.
OP do you know how to properly lower a car w/ adjustable lower bracketed coilovers?
Don't be embarrassed, there are many fuck tards out there that don't know what the FUCK they are doing and try to lower their car by preloading the springs.
Old 12-03-2009, 05:30 PM   #7
d0pe240
yeh i know how to preload the springs. moved the collar up til it was snug against the spring, just enough so it wouldnt droop. the spring looks smooshed because its a smaller spring 150mm vs the 200mm.
Old 12-03-2009, 05:31 PM   #8
d0pe240
could it have been in a accident and caused this?? i bought it used and the owner before me said nothing ever happened to it.
Old 12-04-2009, 01:31 PM   #9
d0pe240
just snug against the spring, no droop and not crazy preloaded, just enough.
Old 12-04-2009, 07:38 PM   #10
PoorMans180SX
PoorMans180SX's Avatar
First of all Megan Tracks don't go that low. My Tein Super Drifts went way lower than my Megans. If you want low coils you should have gotten Stance or PBM.
Secondly, where the heck did you get that spring and what's it rate? It doesn't have anywhere near the travel to deal with suspension travel if you were to hit any sort of fast dip.
Lastly, why the FREAK do you want your frame to rub? That's dumb.
Old 12-04-2009, 10:17 PM   #11
d0pe240
i thought the only difference between megan streets and tracks were the dampening and spring rates? so i figure they should lower the same amount.
i dont what my frame to rub, figure of speech. i got a deal on these brand new. i pm'd someone with megan tracks, sent them pics of the coils and my car they way it is shown in the above pics, and their tracks were lower without any collars removed and not maxed out. so i figured maybe something is wrong with my car? i'll just go to an shop and have them inspect it. i looked around and can not find anything.
thanks for your help.
Old 12-05-2009, 07:37 PM   #12
PoorMans180SX
Yeah, I really doubt that there's something wrong with your car.
Seriously Megan tracks don't go that low. I'm speaking from experience here. I had both Megan Tracks and Tein Super Drifts and the super drifts definitely went lower. You're definitely going to have to remove collars.
Old 12-05-2009, 10:12 PM   #13
d0pe240
thanks for the info man. glad to have someone else that had them and knows for sure.
