Hey just wondering if anyone could give me some info on nistune boards, ive never heard of them but im looking at a car that has one in it, its just a piggyback board but thats about all i know, the car has a base tune on it but it needs a dyno tune and i have nooooo clue where to take it? im up in the northeast, if anyone knows a shop, but i have a feeling like im going to have a hard time finding a shop, does anyone else have a piggy back system that you recommend that isnt too pricey? its a KA-T that needs to be tuned..
![]() Join Date: Jul 2016
I bought my car with nistune. It offers the functionality of a rom tuner setup. Think hondata or something. I'm trying to tune it myself, but I've never done this before and it is a learning curve. I think it is difficult to find shops that do nistune, but i havent really looked around a whole lot either. from what i understand, nistune is soldered onto the ecu. If you want to get rid of it, you will probably be best off getting a whole new ecu.
#3 | |
Most shops that tune the factory ECU actually use a Nistune board to create the tune, then use the Nistune software to burn the new chip they install in the factory ECU.
The Nistune daughterboard replaces the ROM chip that contains all the factory maps with one that is rewriteable in real time. I had mine tuned this week in the Montreal area for 550$ CAD. Made a safe 288 whp on 17 psi of boost, an ISR 3871 turbo, factory internals, and 550CC injectors. I bought the Nistune "solution" last year, and I would not buy it again. It's more geared towards the dyno shops, not towards the customers. Stick with the normal ROM chip tune, or go full standalone and replace the aging MAF based system with a much more modern MAP based one. The new Haltech Elite 750 is really interesting for smaller engines. |
I think someone with enough time / determination can definitely tune their car themselves with nistune. It is much more involved, but that makes it better when it comes time to change your setup later on. Pretty sure you have to ship in your ecu every time you change turbo, injectors, e.t.c. when using an enthalpy tune.
I thought so too. But the changes I had made to the car definitely needed an expert hand. I also got to learn a lot and ask a ton of questions to the tuner at the same time.
I guess you COULD tune it on the road, but max RPM and load is the top of 4th gear, which is REALLY too fast for the road. Way too dangerous for me. So yeah, I got a pro to tune it, learned a lot, and got some HP numbers from the dyno at the same time. |
I bought one used for like $200 bucks already inside of a stock ecu. For THAT price, it was unbeatable. Ran it dyno tuned on 850's, z32 maf and s15 turbo at just a hair over 300whp for like 3 years no problems..
If you find a good deal on a used one they are worth the money. It all comes down to your budget and your goals man, but its definitely not a BAD option. EDIT: You're right about it being difficult to find someone to tune it though. The well-known, well established tuners in my area weren't interested in helping me. Found a start-up guy that was down to dyno tune it for 400 bucks, and he did a fantastic job. |
![]() Join Date: Jan 2010
#9 | |
Sent from my Nexus 6P using Tapatalk |
#10 | |
Andy is the man when it comes to Nistune |
| dyno, nistune, nistune kat ka turbo ecu, s14, tune |
