Hello,
Just wondering would removing the AC radiator help with engine cooling? Would it improve FMIC and engine radiator effectivness? |
![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
the less material "obstacles" that air has to go through to get to the radiator, the better cooling possible. If your car is all factory or just minor upgrades, there really isn't a pooint to remove it. Cars from factory are built with a cooling system to combat/deal with those obstacles (i.e large fans, larger radiators, ect.)...but if you already removed some A/C parts, then go ahead and do it. If not, just do a larger radiator if you want to keep your A/C
https://instagram.com/eck_matthew/ |
almost everything , execept engine internals and turbo, will be changed by spring. I'll be looking for 300hp.I'll probably be running 1.2bar and scramble boost set to 1.5.
Well I never use the A/C. Now I have easy acess to it. But if the advantages of removing the whole A/C would be unnoticable, then I'm not wasting my time ![]() Looks like I'll remove it =] |
Yup in in the middle of fabricating one
Now I was thinking if I'm improving flow before the FMIC and radiator should do something behind as well. Ideally I would want a vent on the hood, V shape the two important coolers and seperate there incoming flow. But for now thats out of the budget =] Now any improvement, that's not just in my head, will do ![]() |
keep your a/c..keep the stock clutch fan and remove the stock a/c fan something more beefy. You'll be fine
hence Be Cool 75062 - Be Cool Qualifier Fans - Overview - SummitRacing.com
MORE BACON STRIPS
| a/c, cooling |
