![]() Join Date: Feb 2009
I have a series 1 rb25det in my s13 and i dont know how to install the q45 (90mm) throttle body. I know it fits directly but i would like some reassurance, any pics or advice would be great, btw its stock cept for 3" tbe runs like a dream
![]() Join Date: Apr 2005
fits directly only if you are using a greddy (style) intake manifold. also the tps is the same so u can use either q45 or rb25 with your S1 incase it didnt come with one
Of topic since it is on a ca18det but may give you an idea.
My +700hp RS13 |
Does the Q45 throttle body TPS fit a series 2 RB25det?
![]() Join Date: Dec 2006
From what ive heard no it wont, it uses a differnet voltage signal
Bringing up an old topic here! I have a s1 rb25 with a greddy intake and a q45 tb and I guess im missing the idle air control valve?
Im not sure where it even goes... Anyone know what year q45 throttle bodies are used with rb25 so I could get one??
BECAUSE RACE CAR!!
well the guy that had it before me has some lines on the throttle body plugged up so maybe that's got something to do with it...
I just don't see anywhere that it could go... Ill post a pic of the plugged up lines later
BECAUSE RACE CAR!!
#17 |
The RB25 IACV is normally located underneath the Greddy manifold with the adjustment screw facing the passenger side strut tower. It should be turned all the way clockwise and then backed out 1/4 to 1/2 turn.
As far as the Q45 TB goes, it has a secondary spring assembly on the throttle plate that needs to be removed in order for the engine to compensate correctly. Also, there are two vacuum lines that need to be capped on the TB so it doesn't bleed unmetered air into the system. |
| q45, rb25det, s13, silvia |
