Old 02-09-2015, 02:27 PM   #1
wiring specialties
wiring specialties's Avatar
wiring specialties is an unknown quantity at this point
S13 SR20DET wiring harnesses BACK IN STOCK!
Our S13 SR20DET engine and transmission harnesses (OEM SERIES) are back in stock. Quantities are limited and the last sets sold very quickly.
If you are looking for a brand new wiring harness that will completely replace every wire connector and ground then this is the harness for you. No splicing or modifications required - OEM fit and finish with a STARTUP GUARANTEE.
Engine harness: $319 - - Transmission Harness: $99 - - Combo Harness: $409
Order here: http://www.wiringspecialties.com/s13sr20det.html
Wiring Specialties Harness Features:
- Plug and play
- No cores or additional wiring required
- Point to point continuity checked
- Constructed using brand new OEM connectors and seals
- Improved grounding
- Retains OEM wiper functionality
- Retains Cruise Control and all gauge functions including speedo and tach
- Works with the Greddy/Freddy intake manifolds
- All A/C, Temp override, Auto On/Off functions properly
- OEM wiring connections and 'T' junctions. No soldered connections at all
wiring specialties is offline   Reply With Quote
Old 02-09-2015, 10:43 PM   #2
lilpiton
lilpiton is an unknown quantity at this point
How much for a s15 sr20 in a s13 chassie wiring harness?
Do you have them in stock?
Im instaling my A/C and was wondering how is this harness wired.
lilpiton is offline   Reply With Quote
Old 04-10-2015, 09:43 AM   #3
wiring specialties
http://www.wiringspecialties.com/s15sr20dets13.html
They are $419 and ready to go for you, and we can gladly have the AC option for you as well
