#301 |
![]() Join Date: Sep 2008
I was able to drive one over the weekend with my friend who's seriously looking to buy one.
So honestly, the car was a blast! It's such a great ride! I didn't find the cabin to be noisy at all (I was reading about that). The car has a nice and real low center of gravity feel, and the handling was magnificent! Really tight feel while driving. And for a stock 4 cyl engine and stock exhaust that engine is responsive and sounds great! I get that the Car isn't fast, but every time you accelerate that 50/50 weight distribution and rwd really makes you feel it. Overall I loved the way it felt and I'd scoop one up. As for my friend, he's looking for a dealer who will sell at MSRP. |
#302 | |||
![]() Join Date: Apr 2003
#303 | |
![]() Join Date: Dec 2007
Trader Rating: (63)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 63 reviews
Without having good knowledge about S2000 can't point out specifics but I have seen many people complaining about their engine reliability issue on their forum (s2ki.com) Sure I've seen 400~500hp with FI/stock internals.. also I have seen 400~500hp KA-T too. just matter of time it will stop handling that power. So I dont think that would be much a good example here. I would't take S2000's side because I owned one before and I didn't like much of the car it self. You dont feel that Awesome 240hp you mentioned until you have to rev crap out it also I think Honda forgot to put Torque in that engine.. As far as Fuel consumption, I am more than quite sure Honda tried to squeeze power out of engine so they really didn't get to get better MPG. BRZ has direct injection plus I am quite sure has more room it self to push harder to get more HP#. But again, it is not always HP/TQ#s to determine which is "Better" engine. So school me what make F20 better than FA20 other than HP#. |
#304 | |
![]() Join Date: Oct 2005
![]() That car has got both those 2L engines beat! ![]()
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd |
#305 |
![]() Join Date: Mar 2007
![]() ![]() ![]() Feedback Score: 12 reviews
As far as hp goes: the s2000 is pretty tapped for power to still be na and street driven. So id say its fully street built? If that makes any sense. The brz is yet to be seen how well it takes to intake and headers. As every s2k owner should know, very few intakes and exhaust gain power for an s2k. And when its a gain, its small.
120hp per liter is pretty damn impressive tho dude so idk why youre trying to count out the f22
#307 | |
Horsepower = torque X Revs --------------- 5250 Torque = cylinder pressure = shit breaking. An engine that can safely rev higher will need less cylinder pressure (i.e. torque) to make the same hp. That's why stock block S2000s make so much power safely. Also, if your criteria for a better engine is gas mileage, then a turbodiesel VW > Lamborghini V12. Let's be real here, as sports car engines, the F20 is head and shoulders above the crap engine in the BRZ. |
#308 | |
2. Provided that you throw every bolt on there is to maximize the amount of air the engine ingests, both cars will create the same amount of force (torque) from the combustion process. 3. In that scenario, the car that revs higher will always make more power. I used 100ft/lbs to keep things simple. So FT86: 100ft/lbs x 7500rpm ---------------- 5250 = 142.857143hp Let's do the S2000: 100ft/lbs x 9000rpm ----------------- 5250 =171.428571hp |
#310 | |
![]() Join Date: Dec 2009
so I guess rod angularity and stroke don't factor into this.... |
#311 | |
Lol @ calm down. It's hardly overreacting when someone is spreading misinformation, especially when you flat out admit you have no real knowledge on the subject. Making a statement like "The F20C isn't reliable" or something along those lines and doing no real research on the subject just makes you a fool. I'm also sure the "many" examples of reliability issues that you were so quick to point out are likely few and far between compared to the build numbers on the s2000. Also just because you owned one at one point doesn't mean you know anything about it, anyone can purchase a car and glance through a forum. I do find it funny how you knock it for having to rev it so high, because it shows you obviously did no real research on that part either. IT WAS MADE TO REV TO 9000 RPM's(AP1's) lol even people that have never driven an s2000 know that, it wasn't designed for low end torque. The s2000 itself has earned countless awards for its Engine, Transmission, and chassis. I don't remember there being too much to write home about from Subaru in quite some time, unless you want to count those piston ring issues they were having in the EJ25. ![]() I honestly have no need to "school you" on this, let alone prove anything to you. If you can't do your own research I'm not going to do it for you.
2004 Corvette Z06 / 1971 240z ![]() Last edited by raz0rbladez909; 06-26-2012 at 07:38 AM.. |
#312 |
you can get with this
![]() or you can get with that ![]() I think I'll get with "that" 'cause torque is where is at lol... but seriously, I like s2000 but they do have their flaws and I'm sure that direct injection has something to do with the fuel economy of the FRS/BRZ other than just gearing |
#313 | |
Trader Rating: (63)
I worked as State vehicle inspector before. a lot of S2000s fail to meet states standard due to their engine issues and emission equipment failure. That's most experience I have with S2000. Maybe I was a-hole failing them because of they are Honda or maybe S2000 drivers up here in NW just suck ?? Just saying..... You brought EJ25 but I don't think it isn't a good example you could compare to FA20. So, S2000 won many awards, but isn't it too quick to judge it has better engine than BRZ? I mean BRZ just came out. |
#314 | |
Trader Rating: (63)
You both are just being offended I think because I didn't take you guys side LOL. Of course what make better engine than another has to with overall performance (HP/TQ, MPG, Reliability etc..) |
#316 | |
maybe I got a little defensive because I always see people knocking the car because of the brand/scene without seeing the potential. Don't get me wrong, I'm no Honda fanboy, in fact this is the first Honda I've ever owned, but when I saw the things the f20/22 were capable of with very little engine work I'm definitely impressed. You are right about the BRZ/FRS not being out long enough to make a solid judgement on its reliability/power potential though, I guess we'll have to wait and see.Back to the FRS/BRZ discussion, I did find it interesting in this motortrend article how it did around the track, especially with the not so great tires.Hyundai Genesis Coupe, Mustang V6, and Mazda MX-5 Miata Specs - Motor Trend - Mobile |
#318 |
Keep in mind that the econo gearing of the BRZ will nullify any torque advantage it may have. They are putting very similar levels of torque to the wheels after gearing.
#319 |
![]() Join Date: Sep 2010
Sorry for the stupid question but maybe I'm missing something? It looks like the dyno sheets above are to the wheels for both vehicles.
Would the gearing not have already played its role at that point? I'd understand the gearing issue if they were numbers to the flywheel.. Full torque at just under 3k rpm is pretty sweet, but no one seems to be able to get rid of the dip after 3.2/3.5k as of this moment. Subaru/Toyota are supposedly looking into fixing this for the MY2014 vehicles though I guess.
-Mike |
#320 |
![]() Join Date: Aug 2006
it is a knock prone part of the rev range as near as I can tell so far, the maps go rich and retarded on the stock ECU in that area. it almost seems like an early peak resonance inducing too much cylinder pressure, or it could be an issue with the DI/Port cross over,
Either way more will be known in the next couple of weeks, I'm getting mine this weekend and it will be a test mule...
I am SKULLWORKS |
#321 | |
![]() Join Date: Jan 2004
did you pre order?
sorry no ebay links, i got it! |
#324 | |
I already posted 0-60 rimes for the FRS/BRZ versus S2000. A 1/4 mile race's outcome should have been obvious.
Purists keep saying the ppl who want this car to have more power just don't get it. Fuck you. That's insulting. What I'd want is a motor that at least compares to the TRD Atlantic 4AGE that every AE86 owner dreamed of having... The S2000's motor is the closest to that goal. Since that type of performance is cost prohibitive for most ppl, I my focus remains steadily on the GC 2.0T. For the guys disliking the Genesis' front bumper: do you think color matching it helps any? I'm thinking a vinyl wrap on that front bumper's midsection will cure a lot of its ills. And maybe remove the lower cross bar grill section all together for more FMIC access and make things less busy looking. And maybe figure out a way to make those silly hood vents functional... |
#325 | |
![]() Join Date: Jun 2005
NOPE. It helps, but does not solve the problem, I think it needs a complete redesign. Small problem in my mind, the rest of the car looks fine. You know my stand on it. Maybe it can be further improved my removing the badging and chrome accents.
#329 |
^^^You know what? That probably would look pretty good having that entire area above and below the colormatched divider completely open. Functional too...
Edit: Oooh... Look what I found. This is the 2013's motor. Too bad the exhaust side isn't really visible though... ![]() |
#330 | |
If I had a pencil and eraser, I'd say completely fill in the badge area, and raise the upper edge of the bottom big air hole so that you could draw an imaginary slightly curved line between the top corners of the fog lights.
