search and you will find
www.massimopower.com PH: 1(951)402-5386 EM:[email protected] Special Thanks To: www.aeperformance.com www.domospeed.com/blog For Their Continued Support |
click me: 240SX S13 5-Lug Conversion i got mine here
![]() Join Date: Feb 2004
^^^ He doesn't have a S13, so there is no need for him to spend extra for conversion hubs. Go to the dealer and order front and rear hubs off any 95-98 240sx SE model. That's all you need. You will need 5-lug wheels and new rotors when doing the conversion. You would have found this if you used the SEARCH function.
Cheapest way would be finding a wrecked SE 240sx in the yard and pulling off the hubs. You can also use the non-turbo 300zx (90-95) REAR hubs. TURBO version WILL NOT WORK. Only thing about buying used/stuff from the yard, bearings could be shot so I would go with buying new. |
