SR IACV delete
I'm searching for info on the IACV delete on the SR. I know this topic has been briefly discussed, but I would like to gain as much info possible.
Please only chime in if you have tried it or experience. Don't tell me it'll idle like crap if you haven't seen/done it before. Thanks all. |
Why do you want to delete it? I can tell you from experience that they are extremely nice to have. Even on a motec system you cant achieve a super clean idle without them.
#3 | |
Reduce clutter, one less system that can go wrong, etc. The main reason is that even with the IACV and correct settings for my TPS, throttle plate, CAS, etc. I still can't get it to idle correctly (as in below 1200 rpm). I've tried 2 different IACV units and it does the same thing so I ruled out that it's not a bad unit. Ultimately, if my car can idle at a better RPM without it, I'll deal with slight fluctuations and occasional dips. |
#4 | |
The IACV really only needs the 1 plug to function the coolant lines aren't needed. So you're not really getting rid of a lot of clutter, you only getting rid of what keeps your idle stable and keeps you car from stalling on decel. Also I'd bet that removing the IACV on a factory system would result in a higher surging idle. Since right now its probably operating at close to 0% duty cycle trying to lower your idle. |
Vacuum leaks have been tested and set screw have been properly set. CAS timing is set as well. These were all things I looked into before thinking about the IACV delete. Coolant lines are already gone. But like I said, the clutter factor isn't the main reason. |
What's the AFR on idle? And im assuming that you did double check the timing at idle with a timing light? Is the car cammed?
Car is completely stock besides basic things like exhaust, intercooler, radiator, etc. Supporting mods basically. AFR @ idle is right around 14.7. Timing was checked with a timing light in timing mode. Sent from my iPhone using Tapatalk |
Check it outside of timing mode. It should be around 15 still, if it's more advanced the idle would be high.
![]() Join Date: Jul 2005
the oem throttle body has a water passage. if you remove that water flow the idle will be higher because hot water is needed to expand a wax element in the throttle body to reduce idle speed.
You should be able to put your hand on the TB and kill the engine that way. If there are leaks anywhere it will keep running. |
The wax element is in the iacv. Coolant flow is needed through the iacv for the valve to close and settle the idle. That is why once your engine warms up, the idle drops. Coolant flow through the throttle body isn't necessary.
http://bosstownfr.blogspot.com/ |
![]() Join Date: Sep 2005
The old I deleted my iacv coolant lines bit. Yeah, you should fix that.
Sent from my LG-H631 using Tapatalk
oh man, its been so long. thanks for reminding me of that, are you sure though? Because I remember for years I ran the water in the TB for some reason. I thought I did anyways.
