electrical troubleshoot
i get a constant power on my se coupe, originally single cam.
but when i go to turn on the car (sometimes) it will click and then no power will be available.
im really confused at this point cause if i wait, it will work again, then it might start or might do that^ again. so i dont see it being a fuse or bad ground, due to it starting all the time for the past few days,then this happened.
im running a black top sr, and there is switches for the fans and fuel pump, fuel pump has a 4 prong relay.
just so you have a idea on the wiring. any suggestions would help
and btw nothing will have power when it happens, everything goes dead
thanks
