![]() Join Date: Nov 2003
Maf sensor on ka24de..
Ok guys maybe this is justme.. but can a maf sensor w/ stand alone ecu or piggyback ecu read boost.. Also.. is there any good way to tune a ka24de turbo w/aftermarket 550cc injectors and no rising rate.. using either a afc or a emanage. i am swaying towards emanage although the afc is on the car already... any suggestions etc...
www.AutoRnD.com Nardi, Enkei, Stance, AME Master Distributors for USA Check Out Our Facebook! |
MAF = Mass Air Flow... reads the flow of air through it. MAP = Manifold Absolute Pressure... reads the air pressure inside the intake manifold. NO YOU CANNOT READ BOOST WITH A MAF SENSOR!!!!!!
yeah that is what i thought.. but what i don't understand is..if you take a look at the greddy e-manage. it shows that they have a add on map sensor. but when i spoke with the guy he says that its auxiliary only to the maf sensor.. now how the hell in the world does this work.
![]() Join Date: May 2003
MAF is used just like stock,,to meter the air coming in.
The add on MAP can be used to set up a timing table that retards based on intake manifold pressure...say .5 degrees of retard for every one pound of boost. 2 separate functions... - Brian |
