Old 05-20-2007, 09:44 PM   #1
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
S14 SR20 swap, help with some lines I'm confused on
This is my first SR20 swap so bear with me. It is an S14 into an S14 chassis. I need to no where the following lines connect to. I go the fuel lines figured out, but I have an extra on coming off of the other hard fuel line, and a couple vaccum lines.
to the best of my knowledge this is what I "think" is right.
1) No idea where this goes to.
2) I conected this to the line coming off of the fuel pressure regulator, is this correct?
3,4) I assume that these went to the charcoal canister and since I DO NOT have it what needs to be done with these lines? Take them off completely, "U" them together????
5) No idea where this goes, BOV????
khilgers is offline   Reply With Quote
Old 05-20-2007, 10:02 PM   #2
rps13drift
rps13drift's Avatar
rps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfection
I Never touched an s14 sr20 but i think
1 charcoal canister if its not the fuel return
2 and 3 coolant lines for intake mani/throttle body mine arent hooked up
4 you can run to youre bov
5 to youre fuel pressure regulator
I hope this helps
rps13drift is offline   Reply With Quote
Old 05-20-2007, 11:12 PM   #3
projectRDM
projectRDM's Avatar
1) EVAP vent line, you don't need it.
FORMERLY R240NA
Old 05-20-2007, 11:51 PM   #4
zipman72
zipman72 is an unknown quantity at this point
Out Of S14 FSM Hope This Helps A Lil.
I Give Up.
zipman72 is offline   Reply With Quote
