17x9 front wheels RUB?
Do 17x9 Front wheels rub even with tien coilovers? I heard they his the top perch and I would need 15mm Spacers. Has anybody done this, and not need spacers?
With a positive offset like 35 or so you may need a 10-15mm spacer. If your running like +20 or less you should be good.
REPPIN' NORCAL HARDER THAN HERSHEY'S TURTLE SHELL CHOCOLATE SHIZ!!! |
#7 | |
![]() Join Date: Apr 2003
If you have an s13 you will need a 8mm spacer, no extended lugs needed. How do I know this? Because I have the sprt MAX 962 rims on my s13, and s14.
#8 | |
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 3 reviews
Most come with extended studs and screws for your original studs. ![]() Like above. And to top it off, you'll probably regret not getting 25mm if you buy 15mm because most people end up wanting a bit more "poke" |
![]() Join Date: Dec 2006
around +20 will be fine
this is my 18X9.5+20 with NO spacers on an S13
後輪駆動車1番1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online #/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
17x9+22 dont rub on an S14 with Eibach Sportlines on KYB GR-2s, since you have coilovers you will have more inside clearance so id say a +35 shouldnt rub but theres only 1 way to be 100% sure
RIP: 95 "Slamry" | Welcome: "Blurple" 96 240SX SE
#11 | |
![]() Join Date: Jun 2004
Trader Rating: (73)
The lowest offset you can go on an s chassis with coils and 9" wheels is a 17x9 +25-22. That's getting lucky, it also depends on how you have your preload set up.
#13 | |
Trader Rating: (73)
I find that hard to believe since I had an S13 with 17x9 +12 (5mm spacer) with a 215/45/17 and it rubbed when turning. See the tire on the fender? You can see smoke from the tire rubbing.
Nice viper. Thanks, I actually have the sportmazz 962's. Also I have the Rota Grid +15 offset 16x8. I have some volks te37's but they dont look great. Thanks guys. I will try the 8mm studs first. The rear I am putting a widebody on, So I will need some spacers back there. Thanks.
#15 | |
erghhhhhhhhhhhhh and im pretty sure Grids are +10mm not 15mm
91' 240sx Fastback LE |
#16 |
on my s13. stock fenders. front wheel - 17x9.5 +14 and also 17x9 +4 or something.
on my S14. stock fenders. front wheel - 17x9 +-0 I rubbed some tire on the fender here and there, but then again, the cars were low.
#17 |
thats a noble not a viper.
i rock 17x9 +22 with a 10mm spacer and i have no rubbing issues. |
#18 |
im using those,i still rubbed but that was the inner linear,also rolled my fenders.17x9 +35 all around
#19 |
Grids are +15, Custom for my AE86, but I am selling my AE86 soon. I just decided to widebody, and convert the front to s15. Since I sold my MK4 supra I am kinda depressed. That gives me the excuse to work on one of my cars.
#23 |
if you have megan coilovers, they have extended lower brackets,
http://www.meganracing.com/demo/prod...=588&catid=105 |
#24 |
#27 |
![]() Join Date: Feb 2008
I have tein hrs and sportmaxx 962 17x9s as well.
25mm spacers, 25mm overfenders, and i dont rub (front coils all the way down). I did need 15mm spacers to clear the coils, but opted to go 25 so i wouldnt have to change my studs. Heres a pic: ![]() |
#28 |
Um, so whats the offset on the whees?
#29 |
right now im running 17x9 spaced out to +4 with -3 camber with just a roll and i rub but not that bad only on full lock is when i rub. its flush on the fender oh and my coils are maxed out low with two collars on each side on the fronts. when i had them at 17x9 et 24 i didnt have any clearance issue with my coils.
