Fidanza SR20DET Light weight flywheel sale! $340.50
![]() Endurance Motorsports Sale: Fidanza SR20DET Light weight Flywheel for $340.50 Fidanza Aluminum Flywheels are made from the highest quality 6061 T6 aluminum. The material is fantastic for strength, heat dissipation and of course reduction in weight. The friction surface used is an incredibly strong 1045 steel. The flywheel friction plates are milled to meet extremely high specifications. A Fidanza aluminum flywheel can mate with any type of clutch material, including organic, kevlar, ceramic, metallic and sintered iron. The replaceable friction surface is attached with military grade aerospace fasteners. With these replaceable friction plates there is no need to replace the entire flywheel when the clutch or flywheel is at the end of it’s life, saving time and money. The ring gears used are also made from 1050 steel and are heat treated for durability. The flywheel ring gears are heated then pressed on and secured with grade 8 button screws. Price: $340.50 Click here to enjoy the special! Add the flywheel to your cart and use the promotion code: FIDSR20 |
That is without shipping, but shipping should not be very expensive on this at all.
