ok so i just got this car for a steal... lol um it has a random miss fire comes and goes i cant pin point if its at the same time or wat. before i go mental figuring this out is there any well know problem i can check for. other question is there a vin on the motor anywere. the dude i got it off of says the motor was replaced in 02 ........ i was told the 90 model had problem with the head ? id appricate any help or advice thanks ahead of time!
![]() Join Date: Dec 2006
there were a few issues with the early 300zx, main one is probably the Injectors.
Nissan wired it to where the injectors had power 24/7 which ended up killing injectors over time. forgot about the others though, Im if you google 300ZX common issues you will find out
![]() Join Date: Aug 2011
yes that could also be the case.
this website has a wealth of info that every Z32 owner should know. http://www.ttxtz.com/tech.html run your codes and do this. the 6 P's: proper preparation prevents piss poor performance
www.NYZC.net |
![]() Join Date: Nov 2007
i also have a 90 n/a z... when i first got it, it had the same issues. just like sileighty said, my problem was with the injectors. it would be intermittent at times then all of a sudden stop working. my suggestion would be to swap to the later style injectors and upgrade your ignition system if in your budget.
GIGGITY GIGGITY GIGGITY GOOOO!!!!
Did you ohm out the injectors? try doing that first,
On early Z's the harness isn't all that great. They decided not to put "gaskets" ( a tiny piece of rubber around the edge of the plugs inside) 94+ Z's ave them as wel as the new efi harnesses, anyway no gaskets in the connectors lets moisture in and corrodes the connectors causing a bad connection. I like to use pb blaster and spray all the connectors and sensors with it and using a pick I scrub off all the corrosion (normally turns green). then I use the same pick to close in the connectors and give better contact once I plug them all back up. Try to ohm out the injectors first that way you make sure they're all good and if that's the case do what I mentioned above and let us know how that goes. |
