![]() Join Date: Feb 2002
Enjuku Racing - Wilwood Superlite Big Brake Front Upgrade
Wilwood Superlite Big Brake Front ![]() This brand new big brake upgrade comes from Wilwood. Nearly identical setup to our drift cars, these 4-Piston calipers will clear stock S14 wheels. No need to worry about offsets and spoke design with the larger calipers. Kit Features: 4 Piston Forged Billet Superlite 4 Calipers Calipers available in Red, or Black 12.90" GT Slotted or SRP Drilled/Slotted Performance Rotors GT Series Aluminum Hats Performance Brake Pads Custom Caliper Mounting Brackets Mounting Hardware & Instructions ABS Compatible Now Available for 4 and 5 lug. The first 4 lug bolt on brake kit for your S13 Be sure to leave a comment if you want the Slotted or Slotted/Drilled, other wise you will be shipped slotted only All Wilwood kits come with a black e-coating on the rotor, once the pads have been bedded in properly this protective coating will come off the rotor surface. In Stock and Ready to Ship! $1,069.99
