#91 |
vq
Hi my name is stefano Begazo from Peru and i have a vq35de and also 260z so i have a question for the swap can i used the oem ecu and throttle body electronic because i dont know if i need a haltech or anther one open ecu thanks for the help
if i can use only the oem ecu NOT FLASHED which another things i need to use ecu harnes bcm fuse box throttle body ecm somethings else''? |
