bee*r power builder into 95 240sx
Hello everyone im having trouble finding the wiring diagram for installing the bee*r power builder into my 1995 240sx. I have searched and searched and searched for this and have found nothing. Does anyone have any links or diagrams that you can share with me? I think the biggest problem is the debate whether the 1995 240sx is obd1 or obd2. i have found diagrams for obd1 but not obd2. The obd1 ecu has a series of 2 rows of wires in the connector, and my connector has 3 rows. Any ideas?
![]() Join Date: Apr 2006
this literally took me 2.68 seconds to find on google.
Bee-R revlimiter Install Diagram - S-Chassis.com
Oh thank you sir your good at finding stuff fast but unfortunately the wrong stuff! Like I clearly posted I need a wiring diagram with three rows of wiring not two like the one you just shared with me! Thanks for reading my entire post. Anyone else, that can read, have any ideas?
Maybe if you knew how to read, you could find a pinout of your ecu and just match the plugs like any normal person instead of asking for us to spoon feed you.
Thanks for playing. Download the FSM
actually Jtuned andy that is the wrong diagram for his car. that is a s13 obd1 not a s14 obd1.
for 95 ka24de obd1 install i used pins: 43 for the ground(black) 56 for the power (red) 40 for the yellow 41 for the Green cut the grey wire for for 4 cylinders use this pin diagram for reference ... hopes this helped out anyone :> |
