![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
Fan noise issues????
For Past couple of days the fan on my car all of a sudden got louder and seems to blower harder at low rpm and high rpm what seems to be the reason for this?
![]() Join Date: Dec 2002
Clutch fan is locked up. Replace as required.
#4 | |
Do a search, there's a thread just recently on the benefits of a clutch fan over electric. Plenty of good info.
That's the terminology used, actually backwards wording. When the clutch fan goes out it free spins dead without resistance.
Trader Rating: (79)
So my in other words my clutch fan is out & it is just rotating due to the PS belts moving it and that's why it's making the loud blowing noise when I give it gas?
That’s exactly what’s happening. The clutch is supposed to disengage at a particular speed and temperature. Yours is not doing that anymore. I have the exact same issue right now. It is affecting my performance and gas mileage big time. I just bought a new one at Autozone for $39.00. Easy fix.
Quick question, does anyone know what clutch fans are interchangeable with the s13 sr20? Can i use an s14 sr one?
#10 | |
Trader Rating: (79)
My Build: The "Coupe De Ville" 1JZ Build!! |
So does anyone know about the s13sr cluth fans? Really need question answered, sorry for thread jack.
Trader Rating: (79)
its koo you aint thread jackin i dont have that problem anymore & sr clutch fans are practically the same as ka ones
Trader Rating: (79)
oh yeah i dont think there the same in the way they can fit one another but i guess you can try.......
clutch fans arent supposed to be exceeding loud. if its really loud, its either no longer working correctly or you have a bad bearing in your water pump, which if thats the case will eventually cause the water pump to explode violently. . . its happened to me before.
replace the clutch, then see if it still loud. |
#17 |
yup your fan is "locked" up. i think mines trying to but i dont really care right now because the worst thing that happens is bad gas fuel economy and the fan blow really hard. it shouldnt break anything just keep up engine a little extra cool.
