#31 |
Drifting all comes down to technique, Learning to work with what you have is what you need to do first... if its not rwd, that would be a platform you need to achieve before you can honestly see true results.
Like everyone said, .,;:'"?/! <---- these go a long way. If your working with a stock KA, enjoy it until you have errytang to swap you prefered engine into your s chasis. I personally have a stock-ish 300zx, inner tie rod spacers, some sort of aftermarket springs, and an exhaust... The springs make the Z very stiff, but not to my liking(harsh ride, yet excessive roll.). I most likely need to get coils, then do the rest of the suspension. IMO your mods should be in this order: 1)maintenance if needed.(replace fluids, repair leaks, brakes, shocks, checking all bushings and related suspension components. If they are in good shape then your set.) If everything is in good working order, move to step 2. 2) Chasis rigidity: ~Welded diff, tig welded if possible, or a 1.5/2 way diff. ~solid subframe bushings ~energey suspension bushings everywhere else ~coilovers(spring rates differ, im not sure what you poo-forty douches run jkjk)~sway bars & endlinks Then by that time you'll be informed enough to make other decisions for power level. |
#32 |
First 3 things you need. Yes, NEED
1. 2 way LSD 2. Bucket Seat 3. Coilovers
#33 |
![]() Join Date: Jul 2007
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
youre location is maryland but you have 559 in your name... confused where you from, aside from that... suspension is a big part. Another is getting to learn your car and getting comfortable sideways.
A day late, a buck short, nothing zip ties cant fix |
#35 | |
honestly, you dont need a 2 way now..maybe later on. a vlsd should be fine, get comfortable with the ka and learn how to throw the back end out on command. also the obvious suspension mods..and you are good to go. once you finished with suspension, you can throw a blacktop or even a RB and have some ball busting fun |
#36 |
I say learn to drift with stock suspension, horsepower, and just an lsd at first. If you can learn how to drift when it's a little harder to get sideways, when you have a few more ponies getting sideways will be easy.
Pearl White s13 |
#37 |
I am a welder/fabricator for a living so tig welding the diff is no problem.Also chassis rigidity is no problem either.I will most likely be caging the car and making my own solid subframe bushings ....I appriciate all the useful info.
#40 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
For a good set of Coilovers I would say get some Powered by max. They are decently priced and I have heard nothing but good about them. I am almost thinking about selling my Tein's and going PBM.
#43 |
![]() Join Date: Nov 2009
You may also need some cool aero mirrors
http://sterlz.wordpress.com/ |
#44 |
![]() Join Date: Jun 2007
![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
to drift you can do it without any power, you can drive your car up to lets say 88mph. Shut off the engine and leave it in N, approach with the speed you want then turn in direction u wanna drift and lock rear wheels for a split second and let the car drift, counter-steer of course. Just make sure you have plenty of space around you. This is a real great way to learn.
#48 |
![]() Join Date: Oct 2010
A good LSD is by far the most important thing... followed by suspension/coilovers... Having more power just makes it easier to push through turns while sideways.
#49 | ||
![]() Join Date: Jun 2009
bucket seat with a good harness too. of course no cheapo coilovers, the dampening is the most important part. with most of the cheap versions, they do not test according to the weight of the car and how its balanced. companies like tein, stance, fortune auto etc. Quote:
#50 | |
Thanks man. I also concur with what you said. Lol. |
#51 |
Welded diff, coilovers, bucket seat. As well as decent front tires, and bump the psi up in the rear tires. That along with an alignment is all you need.
There is another thread on how to drift in this section, so make sure to read through that as well. |
#52 |
Ghost of Zilvia past
![]() Join Date: Sep 2003
There's some good advice in this thread, so take heed.
A lot of guys have been doing this a long time, and know what they are doing. Personally, I think building a car that's a good simple foundation for learning on from the start, and then keeping it that way for a long while is the best way to go, that way you can increase your skills to eventually match the car, rather than fighting the limitations of it, or having to adjust to the latest modification each time. I've had both SR and KA, S13's, Miatas, and AE86's, and I've got to say, the following setup will keep you happy for a very long time. S13 Stock SR20 swap entry-level to mid-grade coilovers from a reputable company. A one-piece bucket seat, with a 5-point harness. A good VLSD (You honestly don't need more than this for quite a while, I started drifting in 2003, and still haven't swapped out my VLSD despite having a new Cusco sitting in my garage since 2006. If you can drift with a VLSD, and you can of course, you can drift with anything from open to a welded. In comparison Colin Frost drifted for a long time with a straight up open diff.) A round (this is the key, not off center or flattened on the bottom, or with awkward sized grips) aftermarket steering wheel. You will be surprised at the difference this will make. After getting a few events under your belt, you should trade cars with friends for a few runs. It will start to teach you about adjusting to other cars, and you're able to check out what you like and dislike about your own set-up. Welcome to the community, and I wish you the best of luck. As was said before, for someone who's only been around since 2010, I wouldn't be talking about a bandwagon if I were you. If I were still a mod here, I'd probably be keeping a close eye on you for a while until you could contribute something useful. |
#53 | |
![]() Join Date: Apr 2009
Trader Rating: (25)
![]() Feedback Score: 25 reviews
#54 |
Trader Rating: (35)
![]() Feedback Score: 35 reviews
Good info guys...
my first pirority would be: check and maintain services on your car.... you cant drift if you dont have a healty running car....well you can but its not a smart choice ![]() |
#55 |
#57 |
![]() Join Date: Jan 2004
You'll be fine if you go in the following order:
1.) 1.5 way lsd, 2 way lsd, or welded 2.) coilovers 3.) bucket seat preferably, i'd recommend getting 2 and 3 at the same time, but of course there needs to be practice at a track before, between, and after each step. you'll always learn faster and safer at the track. i've seen all types of beginners with various stages of mods ranging from stock with an open diff to 300+ hp motors; the ones who learn the proper technique are the ones who start from the bottom up. oh and remember to have fun and don't get too serious or else you may get frustrated while practicing.
![]() D-Street.net | bcuison.wordpress.com |
#58 | |
Trader Rating: (25)
coilovers, bucket, harness, steering wheel, welded or lsd, working ebrake, and a GOOD clutch. (im being kinda a hypocrite here since i have a godspeed clutch on my car right now but upgrading soon) |
#59 |
![]() Join Date: Feb 2008
definitely agree with a lot of people on the thread, good suspension, clutch, and diff and a solid car is first on the list, taking advice from people who actually know what there doing is also good, you can learn different techniques and choose the one you are most comfortable with. start off with some events practice basic car control like donuts, figure eights, then when you master all of that, time to use what you learned and try some actual drifting.
#60 |
![]() Join Date: Sep 2006
A VLSD is just like the stock engine.
Some work great after 180 plus thousand miles, and some break. Change the Fluids in your KA when you get it, and change the diff and tranny fluid. A VLSD usually will work fine. I ran one for a few years, Chuck (teal coupe, puzzle hood) ran one for years, a lot of people do, and they work great. Once in awhile you get a lemon, but thats part of us being owners of the CHEAPEST RWD car out on the market. The advantage of a VLSD is a smoother street ride, way safer in the canyon because its much more progressive the way it steps out, and awesome for autocross. You get great launches, but it wont spin you out in the corners. BTW, I am currently on a welded. |
