SHIPPING AND PAYPAL NOT INCLUDED! Most prices are OBO, so feel free to throw me offers. Combine stuff for more discount. If you see something in the pics but not mentioned, feel free to ask. All offers, PM me. Any questions, post here for all to see.
Most of the S13 Chassis parts came from a 240 I sold that had 85,000 miles. Refer here for older version threads: xpertsnowcarver's Part-Out V2 xpertsnowcarver's Part-Out V1 Carbon Competition Clutch, Hicas Sway Bar w/ C-Pillar Brace, AEM Oil/Water Temp Gauge Disclaimer: All sales are final, sold as-is. There are ABSOLUTELY NO REFUNDS (with the one and only exception of "lost during shipment." That means, no one signed for it. Shipping cost is non-refundable!). Buyer assumes all responsibility. Think of it like a Junkyard that has a No-Return Policy. Please don't ask me if the item works. I'm just going to answer as honestly as possible by saying it functioned when I used it (such as the coil-packs or MAFs). If an electronic fails on me, I throw it away, not on my shelf. However, I won't accept a refund if it doesn't work for you. You've been warned. S13 #27 GREEN ECU ECCS A11-B47-G10 1991 KA24DE (Auto has higher rev limit.) $10 S13 Hazard Light Switch $3 S13 OEM Oil Block M19 Thread $5 S13 MAF KA24DE 22680-53F00 (From 1991 240SX) $10 S13 MAF SR20DET 22680-52F00 (From 1992 Silvia) SOLD S13/s14 SR Coil-packs (x3, sold each) $15 S13/s14 SR Coil-pack harness (x2, sold each) $25 SOLD S14/s15 Coilpack Cover $25 SOLD Key Ring Illumincation Light (From Maxima, Get Creative) (x3 sold each) $5 S15 480cc S15 injector (x1) $25 S13 (91-94 Behind radiator) AC Fans (x2 sold each) $20 S13 (89-90 In front of radiator) AC Fan (x1 sold each) $10 Z32 MAF 22680-30P00 N62 (Cut for couplers use on both ends) w/ pigtail and coupler $70 S15 SR Knock Sensor Sub-Harness Only SOLD S13 Pair Chuki Bumper Vents (x2 Pairs, sold in pairs) $15 1 PAIR SOLD S13 Chuki side extention (Left only) $10 SOLD S13 SR Fuel Rail (No Caps, No FPR) $5 S13 Front Beat Up Mudguards SOLD S15 Autech 6 Speed Nismo/Exedy Flywheel (Need for 6MT Conversion) $200 S15 6 Speed Crossmember (Needed for 6MT Conversion) $40 S13 Open differential w/ output shafts $10 S14/S15 Head (w/ Damage) includes oil drippers, cams, vtc/vct gear, valves, springs, retainers $50 S13 RUCAs $20 S13 Emissions Charcoal Canister $10 S13 Emissions Exhaust Pulsar Unit $10 S13 HICAS rear sway bar (great for drifting, giving C-Pillar brace with it) SOLD S13 Tension Rods $15 S14 SR BOV w/ hoses $20 S13 Steering Knuckles $20 SOLD S13 Outter Tie Rods and Castle Nuts (w/ one inner tie rod) $10 S13 Rear 4 Lug Hubs w/ Bearings (From 1991 240SX that had 85,000 mi) $30 S13 Front 4 Lug Hub (one only) (From 1991 240SX that had 85,000 mi) $10 S13 SR Turbo Manifold $30 S13 Catalytic Converter $50 SOLD S13 Exhaust to Tranny Mount/Bushing (New) SOLD S13 Front Seats (Beat up. No buckles) $10 S13 4x114.3 Spare Rim (x4, sold each) $5 S13 Chuki Canadian Daytime Running/Fog Lights DTRLs $120 SOLD S14/S15 Headgasket $40 S13 Dashboard Cover SOLD PBM (Powered By Max) Oil Pan Magnetic Drain Plug $8 HKS Turbo Outlet Compressor gaskets Real (Came with each of my HKS WGs) $5 Exhaust elbow T2 Gaskets (5 bolt) (x2, sold each) $5 Exhasut gasket to Downpipe $5 Copper Gaskets PN 11026-01M02 (x2, sold each) $2 Random Gaskets, Plugs, Washers, etc (See Pic) $ASK NGK-R SR Spark Plugs (4 new, 4 used still some life) SOLD AEM (NEW in Box) EGT Sensor w/ bung and harness $140 Mishimoto Radiator Fan $30 Mishimoto Radiator Cap $10 S13 RHD Gauge Pod $10 HKS BOV Fake $30 JGY Top Feed Fuel Rail $70 JGY 96lb 1000cc Injectors w/ pigtails & resistors (x4, sold set) $200 100A Fuse Block w/ container for sound system (NEW) $20 Fuse Block for 8g (Gauge) $3 Fuse Block for 8g w/ 40A Fuse $5 T2 Turbo Compressor Inlets (2 bolt) (x2, sold each) $10 T2 Turbo Compressor Outlet (3 bolt) $10 S13 Ebay Front Strut Bar (w/ extra cross bar) $20 Competition Clutch Stage 2 Carbon with Pressure Plate, Pilot Bearing (No release bearing) $200 Greddy Oil Catch Can SOLD Top Fuel Zero 1000 Oil Catch Can (I love this can) $60 SOLD AEM Oil/Water Temperature Gauge w/ sensor $140 SOLD Apexi Drop In Air Filter $10 (Will NOT ship. Not worth it with shipping!) Voodoo Vacuum Block $10 Godspeed T2 Turbo Elbow SOLD T2 Top Mount SR Manifold w/ T2 Turbo Elbow to V-Band Pipe $50 T3/T4 Top Mount SR Manifold w/ WG Flange, Junk WG, EGT Bung $200 Exhaust Silencer for 4.5" tip $10 Circuit Sports Downpipe w/ Flex Section (Beat to Shit) $10 (Will NOT ship. Not worth it with shipping!) Greddy Steel Downpipe (Dented, Very Old…) SOLD 245/40R17 Bridgestone RE-01R (x1, sold each) $20 Random Couplers, Reducers, Elbows, etc (See Pic) $ASK Random Piping, hotpipe, cold pipe, some with BOV Flanges (See Pic) $ASK Random Hoses, check valves, bov valves, pcv, -10AN M22 Earl Aeroquip (See Pic) $ASK Dynamat 1 sq foot sheet (x2, sold each) $5 STRi Oil Sandwich Block/Plate/Adapter M20 Thread (I used this on my S15 Autech SR20DE for a short while, then ended up selling the engine. However, I've found that some SR oil filter threads can me M19. So, be sure it fits before you buy. No refunds! Comes with what appears to be an AEM water/oil temp sensor) $40 DISCLAIMER: For the following items listed below. I have no idea if they function correctly or not. I've had them chilling on the shelf for a long time. If you buy it and it doesn't work, oh well. You were warned. No refunds! It's simple, if you feel the risk is too great, just don't buy it. S13 370cc Redtop injectors w/ pigtails (x4 sold set. SEE DISCLAIMER) SOLD S15 SR AC Compressor 92600-85F01 (From 2000 Silvia SR20DET. SEE DISCLAIMER.) $20 S13 SR AC Compressor 92600-52F03 (From 1992 Silvia SR20DET. SEE DISCLAIMER.) $10 S13 KA AC Compressor 92600-53F01 (From 1991 240SX KA24DE. SEE DISCLAIMER.) $10 S13 MAF KA24E 22680-40F00 (From 1989 240SX. SEE DISCLAIMER) $10 Spare Oil Temp/Water Sensor (sensor & pigtail only. SEE DISCLAIMER) $5 Last edited by xpertsnowcarver; 08-06-2013 at 10:40 AM.. |
Please do not count as a bump. Ran into the 50 picture limit. I'm sure I'll be adding more pictures in this post in the future.
Bump 1
Most stuff is OBO |
#13 | |||
Hey guys, Sorry for the late replies. Been busy, and not on as much now that I sold my 13s.
If you are referring to 3" exhaust gaskets, unfortunately, I do not! Sorry. Quote:
Haven't had time to measure. Stop by! Quote:
#18 | |||
I do not. Sorry. |
#21 | |
#25 |
Tension rods are still good, no cracks or leaking out oil. Are you located in the US? I won't ship int'l. Sorry. |
#26 |
Need a 90* or L-bend 2.5" diameter aluminum pipe, 12" length end to end will do.
Also need a straight 3" diameter, 6" length minimum, 12" max. Looking for aluminum only. Please PM me with a price shipped USPS flatrate to 96740. If you by chance have 2.75 to 2.5" straught and/or 2.75 to 3" 90* silicone couplers I could use those too. Prefer in blue or black color. Thanks. |
#28 | |
Thank you! OP is updated. |
