Need some insight, S14 isn't starting
Hey so I just bought a S14 with a sr20det swap a week ago. The thing was running fine. Then I went in and started to just change out some of the hoses for silicone ones and rearrange the wiring (I'm pretty sure I only touched the speaker wires for the sub and amp) anyway I was just trying to organize the engine bay a bit. Later I try turning it on and it won't start. I think it is a fuel pump related problem cuz it revs and sparks and rumbles a bit but doesn't make it. Seems like it ain't getting any fuel. I'm a noob so could really use some veteran insight. Any ideas. I'm pretty sure nothing is wrong mechanically with the engine. I think I might of accidentally moved or messed up the wiring for the fuel pump
