Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Specific Topics > Archive and FAQs
Archive and FAQs Archives and Frequently Asked Questions about the 240SX are in here.
Old 03-27-2002, 02:08 PM   #1
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
In order to convert kg/mm to lb/in do the following. Multiply the kg/mm amount by 56. So if you kg/mm spring rate is 6 kg/mm Front and 5 kg/mm Rear your lbs/in would be 336 lb/in Front and 280 lb/in Rear. Pretty Simple.
Below is a archive of Spring Rates for various stock and aftermarket springs for the s13 and s14. Enjoy, Please post any additions you may have to this list. Thanks!
<hr color="#000000" size="1" width="100%" align="center">
s13 Spring Rates
Stock '92 (from FSM)
Front & Rear: 102 lb/in
Front & Rear: 110 lb/in w/ HICAS
Eibach ProKit
Front: 114-200 lb/in | -1.8"
Rear: 114-148 lb/in | 1.6"
Eibach Sportlines
Front: 137-230 lb/in | 2.2"
Rear: 128-200 lb/in | 2.1"
Suspension Techniques: 1.3" drop
Front: 206 lb/in | 1.3"
Rear: 155 lb/in | 1.3"
5Zigen R-Rate
Front = 2.4-5.2 kg/mm | 134-291 lb/in | 1.3"
Rear = 1.9-5.0 kg/mm | 106-280 lb/in | 1.1"
Tein HA
Front = 6 kg/mm | 336 lb/in
Rear = 5 kg/mm | 280 lb/in
Tein HE
Front = 8 kg/mm | 448 lb/in
Rear = 6 kg/mm | 336 lb/in
Tein RA
Front = 10 kg/mm | 559 lb/in
Rear = 8 kg/mm | 448 lb/in
Tein RE
Tein RS
Tein FLEX
Front = 5 kg/mm | 280 lb/in
Rear = 4 kg/mm | 224 lb/in
Tein S.Tech
Front = 3.2 kg/mm | 179 lb/in
Rear = 2.9 kg/mm | 162 lb/in
Zeal Function B-6
Sreet Spec:
Circuit Spec:
Rear = 7 kg/mm | 392 lb/in
s14 Spring Rates
kg/mm DR21
Front = 4.8-3.0 kg/mm | 269-168 lb/in
Rear = 4.0-2.8 kg/mm | 224-157 lb/in
kg/mm DR Racing
Front = 6.6-3.2 kg/mm | 370-179 lb/in
Rear = 5.2-2.4 kg/mm | 291-134 lb/in
RSR Hard Springs
Front = 5.0 kg/mm | 280 lb/in
Rear = 4.2 kg/mm | 235 lb/in
TANABE SuperH
Front = 3.0 kg/mm | 168 lb/in | -28mm
Rear = 4.0 kg/mm | 224 lb/in | -9mm
TRUST Sport Springs
Front = 2.6 kg/mm | 146 lb/in | -25mm
Rear = 2.6 kg/mm | 146 lb/in | -25mm
HKS Super Sports
Front = 4.14 kg/mm | 232 lb/in
Rear = 3.46 kg/mm | 194 lb/in
Tein HA kg/mm
Tein HE
Tein RA
Tein RE
Tein RS
Tein FLEX
Tein S.Tech
Front = 4.8 kg/mm | 269 lb/in
Rear = 4.4 kg/mm | 246 lb/in
Zeal Function B-6
Sreet Spec:
Circuit Spec:
West - Zilvia.net - Toyobaru.net - NapkinSketch.com
West is offline
Old 04-04-2002, 05:07 PM   #2
Danio
Danio is an unknown quantity at this point
Anyone know the spring rates for stock S14s, base and SE?
Danio is offline
Old 05-31-2002, 11:36 AM   #3
Archangel
Archangel's Avatar
Archangel is an unknown quantity at this point
Send a message via AIM to Archangel
S-14
Apexi N-1 Coilovers
White 98 s14
Archangel is offline
Old 06-13-2002, 03:32 AM   #4
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
This just in: &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
Whiteline Springs, parts 70055 and 70049
Front: 155Lbs/in | 35mm
Back: 165Lbs/in | 40mm
DuffMan is offline
Old 11-20-2002, 07:41 PM   #5
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
S13
KGMM S21 Sport
front: 3.2 kg/mm | 179.2 lb/in
rear: 2.6 kg/mm | 145.6 lb/in
KGMM S21 SuperSport
front: 4.6 kg/mm | 257.6 lb/in
rear: 3.8 kg/mm | 212.8 lb/in
KGMM S21 Racing
front: 6.6 kg/mm | 369.6 lb/in
rear: 5.2 kg/mm | 291.2 lb/in
LanceS13 is offline
Old 02-24-2003, 05:47 PM   #6
AKADriver
AKADriver's Avatar
AKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura about
Stock 1990 (from FSM):
Front & Rear: 112 lb/in (base)
Front & Rear: 123 lb/in (sports package)
AKADriver is offline
Old 03-29-2003, 10:22 AM   #7
hurleyboi514
hurleyboi514 is a well-known jackass
Send a message via AIM to hurleyboi514
RS*R race springs
5.00kg F and 4.5kg R
HighTach Motorsports
hurleyboi514 is offline
Old 04-15-2003, 12:52 PM   #8
sushiplugger
sushiplugger is an unknown quantity at this point
Linear Springs for S13
Tokico
Spring Rate - F : 3.0 kg/mm | 169 lbs/in
Spring Rate - R : 2.7 kg/mm | 150 lbs/in
Ride Height - F : -1.0 (expect -1 ~ 2 inch range)
Ride Height - R : -1.0 (expect -1 ~ 2 inch range)
RS-R Down
Spring Rate - F : 3.0 kg/mm | 167 lbs/in
Spring Rate - R : 3.0 kg/mm | 167 lbs/in
Ride Height - F : -1.5 est. (95-98 240sx drop)
Ride Height - R : -1.2 est. (95-98 240sx drop)
Tein S-tech (I think the ones in the first post are incorrect - I got these from Tein's website)
Spring Rate - F : 3.7 kg/mm | 207 lbs/in (MFG #'s)
Spring Rate - R : 3.2 kg/mm | 179 lbs/in (MFG #'s)
Ride Height - F : -1.5" (MFG #'s)
Ride Height - R : -1.2" (MFG #'s)
Progressive Springs for S13
H & R Sport
Spring Rate - F : 2.0~2.08kg/mm | 112~116 lbs/in
Spring Rate - R : 2.5~2.6kg/mm | 140~145 lbs/in
Ride Height - F : -1.3" (MFG #'s)
Ride Height - R : -1.3" (MFG #'s)
sushiplugger is offline
Old 06-02-2003, 01:59 PM   #9
Strider
Strider is an unknown quantity at this point
S13
Nismo S-Tune (not height adjustable)
_ _ _Front: 5.3 kg/mm | 296 lb/in
_ _ _Rear: 3.9 kg/mm | 218.4 lb/in
Nismo N1
_ _ _Front: 8/10/12 kg/mm | 448 - 672 lb/in
_ _ _Rear: 8 kg/mm | 448 lb/in
I refuse to answer that question on the grounds that I don't know the answer.
Strider is offline
