![]() Join Date: Jun 2002
P2m nissan sr20det silicone radiator hose revision!
Hello Zilvians,
We would like to make an announcement that our P2M silicone radiator hose kit for Nissan SR20DET will now be INCLUDING the top radiator cooling performer hose kit which is a good option for people wanting to install water temp sensor in the near future a breeze: ![]() ![]() With this change, the MSRP price of the radiator hose kit has been raised slightly at $75.00 / set to reflect the increase in costs. Nevertheless, we felt it is still the most bang for your buck radiator hose kit in the market.
![]() 909-594-3619 Business Hours: Mon-Fri 10am-6pm (Pacific) email: [email protected] http://www.phase2motortrend.com |
![]() Join Date: Jun 2003
Trader Rating: (129)
if it comes in red i'll order right now.
Thanks for your input, we will make red color option for next production run.
![]() Join Date: Jun 2004
Trader Rating: (73)
Make some for the KA for s14! There are limited KA options. I'd prefer not to run something with Megan on it.
KA hoses are in the works as we speak. =)
Sent from my D6653 using Tapatalk
Yes upper will also be sold separately.
What did you have that required you to run two sensors?
![]() Join Date: Mar 2009
Nothing other than two defi water temp gauges, one in each hose so I can see the temperature going into the engine, where the factory cluster and ecu temp sensors are located as well.
SOHC engine or DOHC ?
Lol, well its considered DOHC SR. We will keep the lower hose option in mind for future reference.
#19 |
Amen. I run a greddy swirl pot and I would love to have a hose with the fitting already installed so I don't have to cut and install an adaptor. Not like it can be seen that easily, but still it would be an awesome option to have.
#20 |
I would also like to see if you can make an upper hose for those of us running an s13 KA radiator with sr20det. I can't find a silicon option for this setup. I am running a rubber hose and would like blue silicone up top.
Sent from my SAMSUNG-SM-G920A using Tapatalk |
