Old 09-21-2015, 03:34 PM   #1
HellaSexyS13
HellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-known
SR laggy temp gauge
so my temp gauge in my s13 seems to not be reading properly. no aftermarket gauge, talking about the oem one on the dash.
car has an s14 sr20det swap w/ aluminam radiator and electric fans and new t-stat.
the gauge usually gets to just under the 1st bar on the temp gauge after like 30min of driving, ive had it reach the middle mark on the gauge after a long drive but once i come to a stop the needle drops.
the engine def heats up b/c it triggers the fans to turn on, anyone ever experience this before? Do you think its the temp sending unit not reading correctly. the shop that did the swap noticed it and they said they checked temp sensor and it was working.
car runs and drives great tho, any input is appreciated.
HellaSexyS13 is offline   Reply With Quote
Old 09-21-2015, 03:36 PM   #2
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
you need to use an s13 sensor for s13 cluster. Its the single wire sensor.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 09-21-2015, 08:03 PM   #3
HellaSexyS13
ahh! didnt even think of that. thanks! the KA and SR sensors wouldnt be interchangeable would they?
Old 09-22-2015, 10:13 AM   #4
japslapsilvia
They arent "Motor" Specific. They are Chassis Specific. so just match your cluster to the sensor. s13 cluster s13 sensor (KA or SR)
Old 09-22-2015, 11:33 AM   #5
HellaSexyS13
got it thanks, i can just grab one from advance auto i found
