The rear cover is different... thats the only thing you need to swap if you're using an s13 in an s14 or vice versa.
The 2 front bolts on an s14 setup use a kind of bushing in between the bolts to dampen. S13 uses straight bolts. Axles should interchange... just make sure you have the same bolt pattern on the diff flanges as your axles.
S14 240SX aka "The Dirty S14" fizzerkart.com/s14.html |
![]() Join Date: Jan 2006
good to hear. thanks. im asking because i bought a t trax 2 way for a vlsd s13 and my shafts do not match up with the c clip grooves in the diff. tomei sent me diagrams with measurements of the half shafts and both my long and short shaft are longer than what tomei is claiming they are
