| Media Forum / Pictures / Videos Forum dedicated to media, such as pictures and videos. |
![]() Join Date: Aug 2009
Weekend @ Fuji + Nismo Silvia 270R Spotting
Had another track day this past weekend up at Fuji.
New updates on the car: Rocket Factory Crank Pulley Greddy E-Manage A/M FRP hood Car is making a bit more power with the e-manage set up. Could go a bit more aggressive as im told. Anyhow, few photos from the track. The Nismo 270R was just parked, didnt see it on the track at all. On the hunt for one of these loaders just now. The time has come...need to look the part hahahaha I believe garage rental is in the 12,000 JPY range for the day. And some jdm goodness ya prevert! |
Not one to brag but finally had a chance to run a GT86. It appeared stock but at the same time not totally true as we were running over 180KPH on the main straight. These are limited at 180KPH out of the box, like every other car in JDM land.
In the corners and under braking I naturally had an advantage. The Silvia after-all has had a shit load of work put into the brakes / susp. over the years. But will admit that I could only muster a slight speed advantage up to 4th gear, then into fifth we stayed matched. The 4.6 final drive has its advantages and disadvantages / ![]() Just one photo at the start gate. Really need to invest in a vid cam. |
#6 | |
Blitz 75250 Silicone Upper Radiator Hose & Sensor Bung S13 SR20DET |
![]() Join Date: Sep 2006
Feast, great photos. so your car is sr20de?
if you were lookin for silicone hoses for KA, i know enjuku has em *ISIS Silicone Radiator Hose Kit - Nissan 240sx KA24 89-98 - Enjuku Racing Parts, LLC as well as (all available in blue) agency power circuit sports megan
formerly known as "hotboiblaze" ![]() ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
#11 | |
With a future planned overhaul im gunning for 225-250 HP. The head has a lot of room for adjustment as does the bottom end. |
#13 | |
#14 | ||
Feast, wanted you to know i JUST had a dream about the 270 cuz of this thread. also, what are your opinions on boring the sr20 to sr22? too expensive or unbeneficial?
