![]() Join Date: Jan 2008
Missing coolant in coolant reservoir
I poured in coolant into my coolant reservoir yesterday. But after 30 min of driving, the coolant in the reservoir is all gone. The meter didn't show that my 1993 240SX is overheating.
Could the problem be that I didn't open air relief plug when I flush and refill the coolant? Or the water pump is leaking? http://www.240sx.org/faq/articles/coolant.htm Thanks! |
![]() Join Date: Mar 2005
you need to be a little more specific on what you actually did. i.e. did you completely drain and refill the coolant. I gathered you did and didn't bleed it at all. So bleed the system completely and see how that goes. Another problem could just be that your coolant reservoir is cracked and leaking.
http://s165.photobucket.com/albums/u63/ajhartma/ 1990 240sx hatch....currently monster truck status, with sunken battleships. ![]() *Junkyard Scavenger* |
Two months ago, my friend and I completely drain the old coolant, and flushed the coolant system with home water hose. And then, we refilled the new coolant. However, when we flushed and refilled the coolant, we didn't open the air relief plug. So I didn't bleed my coolant system properly.
And then about one month ago, my car overheated in a very hot day. I checked the coolant reservoir. It was empty, so I filled in with drinking water. After that, my car has no overheating issue. However, whenever I refilled the coolant reservoir, the coolant in the coolant reservoir would be emptied after about 30min of driving. The things that are strange are: 1) The meter shows no overheating. The needle stays in the the middle between "H" and "C". 2) There is no coolant can be found under my car. My real question is: Where did the coolant go? So this could be the following problems: 1) I didn't bleed the coolant system properly. Then, why no overheating but missing coolant in the coolant reservoir? 2) The coolant reservoir is cracked, so it's leaking slowly. Or some coolant hose is leaking slowly. 3) The coolant fan is leaking or not functioning properly? Thanks! |
![]() Join Date: Jun 2006
Its your water pump bro. I just had the same prob on my s14 and replaced it and its fine. When I took off the old one i saw where it was leaking out of but couldnt really see too well from where when it was on.
Driftphreak87 |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
I'm actually having the opposite problem. All of the radiator fluid is being returned to the overflow tank. Plus, when I turn off the car after about 15 mins. + driving, it sounds like it's boiling/bubbling.
![]() (888) 611-1776 |
![]() Join Date: Jul 2005
^^ air in the system or blown hg .. its overheating
and to the original OP, my car does that sometimes when I have to bleed the coolant system. You don't always get all the air out, but when that pocket of air goes and lets all the water in, it will come out of the overflow. My suggestion is fill it back up again and see if it goes down.
613DriftWerks.ca |
![]() Join Date: Dec 2002
You're not loosing fluid. The system was never full to begin with, IE it had an air pocket in it. Overheating caused the air to be forced out, displacing it with the water in the tank. Each time as air is purged, fluid is pulled in to replace it. Has nothing to do with a bad water pump or hose unless you're certain it is leaking.
Rebleed the system properly to spec, add the exact amount of coolant/water mix, and for the love of all holy do not use tap water. Your cooling system will be full of rust in no time. Distilled water only.
#12 | |
I found the coolant leak. I want to confirm that I need to replace the water pump. If yes, I will follow the guides.
http://forums.nicoclub.com/zerothread?id=220947 http://forums.nicoclub.com/zerothread/242595 [ame]http://www.youtube.com/watch?v=nDysgdtBzVA[/ame] And about the rattling noise, is that the infamous timing-chain-hitting-the-guide noise? http://www.nicoclub.com/articles.php?id=105618 Thanks! |
That's what my water pump did when it went bad. Another way to confirm is by looking at the weep holes, you should see fluid coming out of them.
613DriftWerks.ca |
#17 |
AFC #1
![]() Join Date: Oct 2003
Look on the side and bottom of the water pump housing. There will be a bb sized hole on the shaft section.
#21 |
There are 6 pulleys.
Left: Alternator Top center: Water pump Bottom center: Main engine pulley Top right: Power Steering Bottom far right: ? Bottom (between main engine pulley and far right pulley): ? Which one is the AC compressor? |
#22 |
AFC #1
Bottom far right: AC compressor
Bottom (between main engine pulley and far right pulley): Idler pulley. keeps tension on the belt.
#23 |
![]() Join Date: Dec 2006
glad this thread popped up... i'm having the same trouble since i did my head gasket swap....
i'll have to look into this next time i drive my car and check for leaks...
#24 |
Thank you everyone.
I finished replacing the water pump yesterday. I didn't see any more leak, but I will check again tonight. I still hear the rattling noise. I think it is the chaining guide. |
