Car won't shut off
Hello guys,
I recently had a turbo timer installed and I accidentally pulled on the wires underneath the handbrake. Now the car won't shut off. I disconnected the turbo timer and recently installed a new engine harness. It still won't shut off. Do you know what the problem could be? Thank you ![]() |
As long as the ignition switch input on ECU pin 36 is ON, the ECU will keep the engine running.
NismotronicSA - Speed-Density Tuning for Nissans |
