![]() Join Date: Oct 2009
Nismo 740cc sidefeed injectors (x3)
Part Number - A46 Z00
Injector #3 failed on me. I bought new units. Continuity tested and all 3 injectors clicked and spit fuel. I would have these cleaned and flow tested, and new o-rings. $75 a piece (includes shipping and paypal) Thanks. http://imgur.com/reimnhA
As long as you're not a ham-fisted retard there shouldn't be a problem. Last edited by Psychomoongoose; 04-26-2016 at 09:23 PM.. |
Th continuity test is more important, I would imagine
As long as you're not a ham-fisted retard there shouldn't be a problem. |
running e85 by chance? I've had 2 fail on me in the past 3 years, running e85 and 93 on and off. Just had one go out on me again, I imagine it's from e85 attracting water and corroding the internal coil causing very high resistanc readings (20+ ohm) on them when I've let them sit too long. Anyway, I need one in the mean time to get running on all 4 cyls again while i shop around for a top feed setup. Pm me
I can vouch, bought one from this guy because one of my nismos went out. It got here a few days ago, i threw it in and car is running on all 4 again. Idling smooth without a misfire, and pulling hard. Thanks.
