![]() Join Date: Mar 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
Z32 uprights onto an S13
I know that Z32 uprights fit on an S13 when using coilovers that have the special fork style end, but has anyone used a Z32 rear strut instead of going with coilovers. I'm curious to see if they bolt right up. I've heard that they might, but I'm not gonna tear my HICAS subframe out to put the non HICAS subframe and Z32 uprights on if I can't use the struts. Also, if you have any other methods to get the uprights to work that'd be great. THANKS!!
DD: '05 Saabaru with full JDM STi 6spd swap Project: '91 S13 Hatch SR20 |
I needed non HICAS uprights to replace my HICAS uprights and the Z32 uprights work with the non HICAS suspension. So when I replace the rear subframe and use toe arms instead of tie rods I can use these uprights. I'm also doing the rear brake upgrade, but that was just another perk. They are also aluminum, so they're light as shit!
![]() Join Date: Dec 2002
Z32 shock bolts right in. You can still use S13 springs, or go to the stiffer Z32 spring.
#6 | |
thats what I needed to know!
