Old 03-12-2013, 07:35 AM   #91
2muchboost
Trader Rating: (33)
Feedback Score: 33 reviews
Keep us posted if you get the trans bracket to work. Like I said I have been in contact with a few members and none of use were able to get it to install properly. The brackets goes into the chassis beautifully but the parts where the R154 mounts onto the bracket has not worked for anyone. Not sure if its any similar to the 2jz setup but the only part where I hammered in the firewall just a little bit is where the starter sits once everything was installed. It was like 1/8 of an inch from the wall so I hammered it in about a 1/4 of an inch in just to make sure it wouldnt make contact due to any movement.
Love the build....+1
Old 03-12-2013, 09:47 AM   #92
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Originally Posted by Big Zee View Post
Might I suggest the Tomei oil block peice ? I have it and its really nice, cheap to buy also, only like 100 bucks, but you have to relocate your filter, but doing so gives you the option to also run a oil cooler.
I have the GREX oil filter relocate box so I can run -10 for a oil cooler also., but the Tomei peice would take away a lot of wory of that peice breaking again.
love your build, and the vids of you in the PARC, you have really smooth runs, keep up the great work mate
Thanks man! I'm using something different for oil cooling on the 1jz, never again with a sandwich plate lol.
I have a mount I can try in the bracket tonight, Xcessive is local to me so I can see what's going on faster than most of you. I keep hearing that the holes are off. I'm happy that people dig the build, I've been through alot of bs, hoping this goes smoothly, so far so good!
di-devol is offline   Reply With Quote
Old 03-12-2013, 10:13 AM   #93
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
Jesus H Crust, you must have been nothing short of Hitler in your previous life... your luck is terrible. Looking like it is turning around for you though.
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 03-12-2013, 10:20 AM   #94
di-devol
LOL, I know right? Was crazy for sure, lets hope the curse was with the SR.
Old 03-12-2013, 10:43 PM   #95
di-devol
Flocked the dash tonight. Holy shit that was not fun. Waaaaaaaay more work than one would think. I used the mini folocker at first until I got the dash cover were I was happy with it. Then gave up and just grabbed handfuls of that and started tossing it on there lol.
There is a lot of excess on there, I'll take some pics tomorrow after it's cured and shaken off.
Cut the water neck to accommodate my KA radiator.
Old 03-13-2013, 10:09 PM   #96
di-devol
Flocking the dash seriously sucked.
Old 03-14-2013, 12:33 AM   #97
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
But it looks badass.
What took so much time?
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 03-14-2013, 09:01 AM   #98
di-devol
The "flocking process" took the most time. Putting the glue on was easy. You get this little canister:
The fibers are like dust coming out of it. Glue drying time is 10-15min, by the time I figured out how to get the dust to come out fast, the dying time was half over. Shaking it slowly worked better than trying to use it like a shake weight lol.
After I got the correct flocking texture using the mini flocker, I gave up and used handfuls of the stuff and kinda threw it on there lightly. That worked alot better, but I would use the flocker first.
Old 03-14-2013, 09:13 AM   #99
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Where did you get the material to do the flocking?
BiG MiKE86 is offline   Reply With Quote
Old 03-14-2013, 09:19 AM   #100
di-devol
Here is the write up I followed.
#/f/tech-talk/254699...uede-look.html
I ordered:
a 1lb bag of black nylon suede-tex fibers
Suede-Tex Color-coordinated Undercoat Adhesive 8 oz. can -Black
and a mini flocker.
Flock It! Flocking Fibers Adhesives Applicators Supplies and Equipment
Was about $55 shipped. Came out really good, I dig it a lot.
The 8oz can of glue was just enough to do the dash. I have enough fibers left over to do another dash.
Old 03-14-2013, 11:08 AM   #101
Extreme Dimensions
Extreme Dimensions's Avatar
come on! keep going on this project.
- Chris Gary
p: 714-278-8000 x 19
E: [email protected]
Old 03-17-2013, 11:03 AM   #102
di-devol
Some more pics as the interior comes together.
Anyone got a good way to get this stuff off?
Manual doors
One of the cool things I have, Conrad Grunewald's door lol.
Got the engine harness off to Fiend Performance, then we'll start on the chassis wiring soon.
Old 03-17-2013, 12:34 PM   #103
240boi115
240boi115's Avatar
240boi115 is an unknown quantity at this point
dude nice build.. that single slammin ka you build is the shit man! mad props!
240boi115 is offline   Reply With Quote
Old 03-17-2013, 06:13 PM   #104
di-devol
Yanked the engine and started to finish her up.
Old 03-20-2013, 09:17 PM   #105
di-devol
Quick questions on fuel cell/surge tank setup. I'm having trouble understanding everything,
1) If I get a fuel cell with a sump, do I need a surge tank?
2) If I could use a surge tank is this a proper way to set it up?(pardon my chicken scratch)
3) if you can read my writing, the two fittings on the side of the surge tank, one for return from rail, and one for low pump in, which one should be on top out of the two?
...and what's adequate low pressure? I see pumps ranging from 7-16psi, 7psi enough?
Old 03-21-2013, 08:54 AM   #106
2muchboost
Trader Rating: (33)
@Di-Devol.....below is a good link to basic information about a fuel surge setup.
1) No, once the fuel cell has a sump you would not need to run a Surge Tank. You would use the Surge Tank setup if you are keeping the stock fuel tank and feeding the surge to and from there. (hope that makes sense.....read the article it will).
2) Really depends on your external fuel pump setup. When I was thinking about running this setup I was going to have a Walbro 255 in-tank feed into the Surge. Then on the opposite side of the Surge I was going to have 2-Bosch 044s feed from the bottom of the Surge into the fuel rail. The above design would be good for one pump if thats what your looking for.
510 – DIY Fuel Surge Tank » RatDat.com
My 2 cents...if you dont mind running a cell with a sump its a safer option. Less intricate setup with less pumps that may cause failure. Get a dual feed sumped cell with 2 bosch 044 pumps and you are good to go.
Old 04-14-2013, 01:22 PM   #107
di-devol
Parts are finally starting to come in.
Mocking up the fuel cell.
Car goes in for the cage at the beginning of May. Then the wiring can get done.
More updates coming as parts roll in.
Old 04-15-2013, 12:57 AM   #108
huffandpuff00
huffandpuff00's Avatar
huffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura about
are you getting the cage done at psi?
huffandpuff00 is offline   Reply With Quote
Old 04-15-2013, 09:50 AM   #109
di-devol
No, going to racetech in portland. PSI and Rhom are both to spendy for me.
Old 04-15-2013, 02:56 PM   #110
huffandpuff00
my old roomate had his cage done at racetech and it was 1800(6pt no gussets). JJ said they could try to match the price pretty close. idk how close pretty close is, i was planning on spending $2000 for a cage.
Old 04-15-2013, 03:04 PM   #111
BiG MiKE86
BiG MiKE86's Avatar
Holy hell that's expensive for a 6pt cage! My buddy got a 6pt cage done down here by a local race shop for $600 or $100/pt
Old 04-15-2013, 03:05 PM   #112
di-devol
2k for a legal cage is cheap up here.
Old 04-15-2013, 03:07 PM   #113
BiG MiKE86
BiG MiKE86's Avatar
That's nuts... lol that's 2k worth of JZ upgrades
Old 04-15-2013, 03:07 PM   #114
di-devol
Ha, why do you think my budget came out to like 8k lol.
Old 04-15-2013, 03:09 PM   #115
BiG MiKE86
BiG MiKE86's Avatar
Shit I'm well past 8k without a cage... This damn swap is not for the typical drifter on a budget
Old 04-15-2013, 03:11 PM   #116
di-devol
Nope, I agree.
I'm keeping the 1jz sealed, not touching anything this time.
So the budget included the cage/fuel/wiring/saftey gear.
Old 04-16-2013, 01:24 PM   #117
di-devol
Finally got the routing done for the fuel cell and surge tank.
Waiting for fittings and hoses to come.
Old 04-22-2013, 10:47 AM   #118
di-devol
Not much of an update, testing colors for the car. Satin Indigo blue pearl seems to be the best looking. Just have to get it mixed up and start spraying now.
Car goes to Racetech on May 4th for the cage and rear bulkhead/firewall.
Picked up Achilles tire, Fiend Performance, and 425 Motorsports as sponsors as well!
Old 04-28-2013, 10:13 AM   #119
di-devol
Got her painted. First time spraying a car with an actual gun(cheap one at that).
Painting the bumpers and skirts today.
Old 04-28-2013, 02:32 PM   #120
BlackBeard
BlackBeard's Avatar
BlackBeard is an unknown quantity at this point
Nice build, just read through it all. One random question, how did you get one of Conrad Grunewald's doors?
BlackBeard is offline   Reply With Quote
