![]() Join Date: Dec 2007
Trader Rating: (38)
removing broken exhaust manifold stud w/ broken extractor
like the topics says i have one broken stud while i was replaceing my turbo manifold.
so drill a whole with a small drill bit and i use the extractor. some how the extractor broke off. now im in some serious Shlt the extractor is titanium and when i tried to redrill a hole it doesnt seem to cut through. Do anybody know if titanium is drillable? anyone had this problem before? |
![]() Join Date: Jul 2007
hmm now you might want to try to extract the broken stud with vice grips. also get yourself a torch and heat up the stud too and have a friend try to coax it out, maybe this will help you remove the broken extractor.
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving |
Trader Rating: (38)
a torch? i'll give that a try
anyone had a similar problem? i dont want to leave that broken stud in my engine when replaceing the new stud. i just dont feel safe with 7 studs holding my manifold |
happened to me a year ago.
one of the studs on the header(KA) broke and was stuck in the engine. went and got a tap/extractor or whatever from sears and started to drill. came out with no problems. gluck with you problem
you could weld on a piece of metal to whatever's left of the broken stud and unscrew the stud out along with that broken off titanium thing.
jumbosandbox.blogspot.com |
dam that sux man, same sheit happend to me, few days ago.
I had to take off my oil pan to weld a fitting onto it, while unbolting it, one of the bolts snaped on me, the bolt head snaped/broke off. It snaped flush on the upper oil pan flange. so i tryed the same thing you did. I first tryed to drill out the stud, but i could not get it to start a hole. so what i did was try welding(i used a tig welder) a bolt onto it, or weld on a washer, then a nut onto the washer. it worked for a short time, then the bolt/stud broke off again, but this time even further down in the hole, so then i tryed the extractor method again and this time i got a hole started, but when i used the extractor it broke off just like you stated, from there, i gave up, and just bolted up the 9 out of 10 bolts on. luckly its not leaking yet. I figure if i have to take out my motor for some reason, ill retry and get the broken bolt out of there. kind of hard working on it upside down underneath the car. but i suggest the welding method, i did research on it and alot of people had success. I think in your case it will be easier since your not welding underneath the car and you can actually see what your doing. that is if you have access to a tig welder, i wouldnt try a mig or a stick welder, to messy and big, not precise enough. |
![]() Join Date: Mar 2006
I've never tried it before, but I would think if you torched the whole area, it would cause the metal to swell, then quickly cool just the stud, and hopefully it will shrink up faster than the hole it's in
![]() Daily driven |
