![]() Join Date: Jul 2006
Trader Rating: (53)
NEW Garrett GT2876R Turbo & GT3071R Billet
///NEW Garrett GT2876R Turbo/// PRICED TO SELL! $1000.00 shipped in USA (not HI, PR or AK) [email protected] - email/Paypal I have a NEW Garrett GT2876R - This turbo is new/never been installed - However the compressor housing has been modified with a V-band outlet as well as polishing (could use some more) - The turbine housing wastegate flapper has been removed for external use/can easily be put back stock if needed (see pix) / I have other houisngs if you would like LMK Compressor Wheel: 52.8mm 76.1mm 48 trim .70 A/R If you would like to upgrade to a drop in Billet wheel for an extra 250 / contact me Turbine Wheel: 53.9mm 76 trim .86 A/R Comes with down pipe - tack welded (see pics) Be sure to use a screw in oil restrictor when needed / be sure to check your oil pressure at the turbo for proper oil pressure. BB turbos require alot less oil than a JB turbo so it is very important to check oil pressure at the turbo to decide what type of restrictor to use! Check Garrett's white pages for great info! Last edited by JDS Performance; 12-22-2013 at 06:32 PM.. |
