#18391 |
I guess you haven't looked through many pages of this thread. The question I've provided is pretty relative to the purpose of this thread. Fitment, Stance, Tires, Wheels. I believe it all makes sense. Thanks though!
#18392 | |
![]() Join Date: May 2007
![]() ![]() ![]() That aside, there's a question thread specifically for questions of fitment and fitment questions. #/f/chat/392494-wheel-fitment-question-thread.html That said, your setup, as you've written it, is not agressive and you will need spacers since you can't get XXR's in custom offsets. Good luck young padiwan. May the wheels be with you.
@be_henney kranstogram is full of nonsense and foolishness. |
#18393 |
Again.
17x9 -25 215/45 5+ degrees of camber all around. |
#18394 |
![]() Join Date: Aug 2005
Ill be nice. With XXR's any offset is going to have the same CONCAVEDISHNESS as the others. They just add more material to the back pad to create more offset.
17x9.75 pisses me off, but +25 is not going to clear coilover in the front. You will need a 15mm spacer to clear most coilovers, maybe even a 20mm on the super safe side. You should run a 215/40 or 225/40, although Im an 18" guy so Im not sure if any good tires even come in 215/40.
#18396 |
#18400 |
![]() Join Date: Sep 2008
Thanks, dick. haha
Definitely not. Never been a huge fan of koukis, but your car is looking pretty rad. Could go lower in the rear, but that's just nit picking. I KNOW people are sick of my car, so I'll leave it at that. haha |
#18402 | |
![]() Join Date: Jul 2011
I might after I get an alignment and get the rear camber sorted out. Completely in the dark for how much I'm running right now. Maybe -5 or so. Then, I'll know if I want to keep it raked like that, or flare the rears, go a hair lower and less camber. |
#18405 |
18*11.75 et23 265/35
18*9.5 et12 225/40 We've built a new set of offset calculators specifically for wheel whores with features we've not seen anywhere else. As well as all the calculations they link through to rimtuck auto filling the search with the details you just calculated so you can see how something similar would look. Everything offset all in one place: Garage LSD Offset calculators ![]()
#18407 | |
Well thank you everybody who provided some information on my brainstorm of a set-up. I'm def going to study this one more. I will be checking out that "Willitfit" calculator as well. After researching a bunch, by the time it comes around I'll probably have a whole different set-up in mind >_<
driftsucky, that picture was great haha. |
#18413 |
![]() Join Date: Jul 2005
Did someone say they're tired of seeing Shreeveco's car?
How about this picture again??? ![]() 17X10 -18 235/40 NT05 -5ish 17X11 -1 245/40 S-Drive -1.3 How about everyone go make their car look good then post in this thread if you're sick of seeing the same awesome wheel fitment over and over, LOL.
![]() Instagram - SJKnoop |
#18419 |
Got my alignment specs figured out. Toe zeroed out. Tie rod is siezed so the caster is still wack, but whatever. No stupid toe wear.
18x10 +/-0 215/40/18 (-2.7) 18x11 +7 235/4018 (-4.0) |
