So my car isn't getting fuel to the fuel rail. i pulled the rail off an its bone dry inside. i checked everything out an fuel gets all the way to the fuel regulator but isn't going threw it.
does this mean i don't have enough fuel pressure or what? |
Unplug the MAF and start the car... If the car idles try plugging your MAF back in. If it dies, you have a bad MAF...
My SR20VET |
alright ill try that. all my spark plug wires an everything are new. i replaced my whole ignition system. i was told its cuz the timing so im redoing the timing right now.
also have another problem. ill take my key out of the ignition an the check engine,brake,seat belt ect. lights stay on when the key is not even in there. its like its stuck in the acc. position. anyone kno what would be the cause off this? |
