Ok , here's what's up.
I followed this DIY off of nico (as I did the last time), only this time I used a 96 Ka Tranny instead of an 93-Ka Tranny. All was going normal until it was time to slip the Sr bellhousing over the Ka guts. It seemed that one of the rods (the lowest w/ the slit in it) wouldnt mate with the bellhousing. I removed the bellhousing and tried shifting the gears only to find out that it will only shift into 1st and second. I dont know if its because the rods werent supported or if maybe I had done the bellhousing removal precedure incorrenctly. A friend of mine told me that if the tranny wasnt in neutral when I took it apart that I could have messed something up internally ,but im quite sure it was. Ive searched most of the more well known boards and I cant really find anyone with the same problem... Help!!!!! |
![]() Join Date: Jan 2006
hit up racepar1, I had the same problem and he took care of it and did a great job.
something wasn't aligned right when you put it back together. There was also no need to take the sandwich plate completely off, bell housing would of been enough. |
