Old 10-17-2015, 03:17 PM   #1
hulkster_s13
hulkster_s13's Avatar
hulkster_s13 is an unknown quantity at this point
Ls2 s13
Location Las Vegas
For sale
1993 240sx with 6.0 ls2 and t56 from 05 GTO
114k on chassis
clean title
36k on motor
Price 14k obo
Motor
Chase bays harness with milspec firewall disconnect
411 pcm, flashed with ls2 program
Monster stage 3 clutch w/ monster lightweight flywheel
Tomei shift knob
GM clutch slave,steel braided clutch line to wilwood clutch master and adapter plate
An fuel lines wrapped in Vulcan fire sleeve
3/8 fuel hard line
Firecore plug wires
Corvette fuel filter/regulator
Corvette engine cover
145amp dr44 alternator
Custom power steering high pressure line made
C4 exhaust manifolds
Every gasket is new including head gasket
Every sensor is new. I swapped every thing for new when I started the swap
4in aluminum intake
Moroso front sump pan from fueled
Custom mounts similar to fueled racing so their headers will work
Y pipe to stock cat back location
Koyo radiator
Flexalite dual fans
Painless thermo controller
Circuit sports overflow
PBM bubbler
Chassis
1993 s13 clean body no accidents and not a drift slut. All clean original interior
114k on chassis
Full interior
Uncracked black dash
Black carpet, black panels
Silvia floor mats
Works bell rapfix quick release
Works bell hub lock
Momo steering wheel
PBM EVDM
pioneer cd deck with aux
Yellow top optima battery relocated to trunk with circuit breakers and cut off
Yashiro factory drift button.
Tomei shift knob
Exterior
Painted about 3 years ago. Garage kept
Koguchi power fenders that I made molds from an actual set of Koguchi fenders
Origin agressive side skirts
Matching front and rear bumpers for origin. I forget the brand basically knockoffs but fit well
Dmax tails
H4 headlights
Brakes
Oem Bm57 17/16 brake master
Z32 booster
Front 350z brembos w/cross drilled/slotted rotors
Rear z32 calipers with ebrake w/cross drilled/slotted rotors
Oem z32 5 lug rear
Ichiba 5 lug conversion hubs front
Suspension stuffs
Aluminum Steering bushing
Energy suspension rack bushings
Ikeya formula inner tie rods
Moog s14 outers
New front ball joints
PBM subframe risers
Newly painted subframe
Racing gear jtcn1
Tein tension rods
Tein he
Wheels
MB battles 17/18 stagger painted white
Hub centric spacers
Cons.
Cracked front bumper
No Ac or heat
http://i3.photobucket.com/albums/y55/eastwind_240/ls2/EEA6D039-BD4F-4B73-A089-9418BA6959BD.jpg[/IMG]
Any questions message me
Link to my build
#/f/showthread.php?t=471423
hulkster_s13 is offline   Reply With Quote
Old 11-05-2015, 11:49 PM   #2
johnnypvrk
johnnypvrk's Avatar
johnnypvrk is on the path to ruinjohnnypvrk is on the path to ruin
Interested in 400hp Fc?
johnnypvrk is offline   Reply With Quote
Old 11-06-2015, 12:07 AM   #3
JDM_Tuner
JDM_Tuner's Avatar
Trader Rating: (35)
JDM_Tuner is an unknown quantity at this point
Feedback Score: 35 reviews
Are you interested in a S13 1jz vvti type x clone? If so, let's work out some terms that work for you. #/f/showthread.php?t=608883
JDM_Tuner is offline   Reply With Quote
Old 11-06-2015, 04:56 AM   #4
MightyMouse13
MightyMouse13 is an unknown quantity at this point
Sorry fellas, already sold to me. Seller's a great guy and the car's awesome
MightyMouse13 is offline   Reply With Quote
Old 11-22-2015, 11:11 PM   #5
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
was this a oahu car before?
supreme_1 is offline   Reply With Quote
Old 11-25-2015, 10:36 AM   #6
krampus
krampus's Avatar
krampus is an unknown quantity at this point
with those weds... so very rad
krampus is offline   Reply With Quote
