![]() Join Date: Sep 2014
maf sensor signal pin to the computer resistance, what reading?
I am trying to test if my maf is bad or my computer.
Could someone please remove their 91-94 s13 maf harness and tell me what resistance they are getting from the harness connector maf signal wire to ground, with the harness disconnected? I am getting a little over 20k on my ohm meter. The maf isn't sending any signal volts when I check with a push pin and volt meter while running. Wire is good, tested perfect continuity, no resistance from ecu connector to maf connector. Now I just got to eliminate whether the computer or the maf is screwed. Thanks! |
Hey your flooding issue, did you fix the problem with a new maf? My S13 is flooding with fuel, injectors are not leaking, somthing is telling my ecu to spray fuel and keep spraying
