#301 |
![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
car looks great so far. are you planning on doing any type of dry sump oil system or anything along those lines?
https://instagram.com/eck_matthew/ |
#308 |
![]() Join Date: May 2008
Wow, very nice build. A lot of work on this!!! Keep it up!
![]() I think this is the best/cleanest fuel setup i've seen!!! Frank
Life is a beat to beat |
#309 | |
![]() Join Date: Jun 2008
Nah I like the raw look of the stainless fitting more
Thanks Quote:
Yeah you can say that. Thanks man, the hardlines does make a big different. |
#310 |
![]() Join Date: Oct 2007
i look for update everyday :P !!!
sick built . this is how a SR2*VE should be done for your canards is nicer the way it is right now but for thieves it's not to hard for them !?!?! |
#311 | |
Thanks for your kind comment. In regards to the canards the stainless fitting are also there for strength as well. |
#318 |
More updates.
AEM pencil coil wired up We decided to drill a small hole through the firewall so the coil pack wiring can go through And this is what on the other side M&W CDI Relocated in cabin fuse box We also drill another hole for the alternator and starter motor wiring Headlight, horn and radiator fans wiring Oil catch can with breather fittings Modded the water inlet with a -an fitting for the header tank Modded the header tank with -an fittings since it didn't come with one And last one for today, brush on under body sound deadener for the front tubs |
#323 | |
![]() Quote:
No I'm on the other side of the country. It's a custom made one...to fit within that space behind the strut tower. |
#325 |
![]() Join Date: May 2006
correct me if i'm wrong, is that a FWD power steering pump. i notice a significant change in the power steering change.
18g and 20g turbo users click on me #/f/tech-talk/261219-18g-20g-turbo-users.html
#326 | ||
No it's still an S15 PS pump, it may look difference due to the fact that it have a different bracket to allow it to be where the AC used to be. |
#327 |
More pics
So the wiring is pretty much done bar in cabin. In regards to the engine there just bit and pieces to do ie cold pipe, more fittings etc etc then it be done. On to the pics Radiator setup Header tank return line Turbo hot side Oil catch can Semi finish in cabin ID 2000 Injectors and wiring Engine bay Rear Side Front |
