![]() Join Date: Feb 2002
Enjuku Racing - ISIS Performance SR20 Intake Manifold *$199.99*
ISIS PERFORMANCE INTAKE MANIFOLD - SAND FINISH - NISSAN SR20DET S13 IN STOCK AND READY TO SHIP! ONLY $199.99! ![]() ISIS Performance Intake Plenums are designed to optimize performance in high performance engines. The cast-aluminum intake manifold allow for large volumes of air to get evenly distributed to the cylinder. To achieve the most form turbocharged vehicles at higher boost levels, ISIS Intake manifold is a must. ![]() All Aftermarket intake manifolds require modification to throttle cable bracket or the purchase of the S14 SR Throttle Pulley Wheel. ![]() Be sure to Add the ISIS Intake manifold Cold pipe to your intake manifold order. Easily install your ISIS intake manifold utilizing this Cold pipe. No need to build a custom pipe, just bolt this one right on!! ![]()
