S13 jdm low mileage sr20det motor part-out and misc
Hey guys, I got two jdm motors parting out and some S13 parts . One was a red top and the other was a black top. This is what I have for sale, nothing more. I will upload pics when I get the chance. I will update this thread as things are sold.
I’m looking to get these things out so some have prices and others are best offer. I have a lot of the hardware too that is bagged and labeled if needed. I can ship parts if buyer covers shipping. I use PayPal and buyer pays fees. THREAD UPDATED AND THIS IS WHAT I HAVE LEFT; -Crank woodruff key -s13 oil pickup -s13 Power steering pump reservoir -Redtop OEM timing chain kit. Includes timing chain, 3 guides, ver.1 tensioner -oil pump spacer -coolant sensor with thermostat and thermostat housing -Redtop OEM cam gear sprockets w/ hardware -Redtop OEM intake manifold -2x upper Oil pans. One set of hardware -Stance water neck sensor adapter w/ oem water neck and hardware -T25 OEM turbo outlet -Redtop OEM water pump -Blacktop OEM water pump -Blacktop OEM oil block -Alternator bracket -Redtop OEM motor mounts brackets w/ hardware -Redtop Crank girdle -oil dipstick tube -Oil pan baffle -Redtop rear main seal carrier -2x upper water neck -New oem rear main seal -s13/s14 timing chain tensioner -blacktop hydraulic lifters -Oem camshafts - Turbo clocking plate \\\SR20DET Electronics/// -Oem maf -knock sensor w/ wiring specialties harness and hardware -Blacktop coilpacks and harness -Blacktop engine harness. Works perfect \\\SR20DET Trans/ Drivetrain/// -2x Pilot bushing -Sr20det driveshaft and bracket -Z32/j30 5 bolt diff axle flanges Last edited by trak-shuhn; 06-17-2019 at 12:19 PM.. Reason: thread updated |
Hump day bump day. starter sold, alternator sold, dipstick sold, oil pump/ cover sold, water pump pulley sold.
things are moving, note that i have most of the hardware and smaller items like the woodruff key if needed. |
#20 | |||
#23 |
Another ignitor chip sold. I still have some good parts. Some highlights are the SR engine harness, driveshaft, down pipe... make offers, im just trying to get rid of stuff. No offer turned down
#27 |
| 240sx, partout, s13, sr20det |
