![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
Mr2 aw11 tire rubbing
alright. aw11 lowered on eibach pro kit. on the way home i was cut off and swerved across both ways finally hitting the guardrail lightly. ok idk if its that the car needs an alignment (because it does, as per the seller when i bought it a couple days ago) or the guardrail, but today on the way home from college i smelled burning rubber and i wondered if it was my car. i got home
check to see if anything was rubbing the tire. me checking - "no, no, no, daaaamn". i found out that the shock, the bottom part that holds the spring, was rubbing the top corner of the tire : ( (front right btw)alignment or is something bent? thank you! |
i can put a picture of the front wheel like 2 ft. back. but i cant take a picture of the tire rubbing the shock because theres literally no room. you can't see any suspension parts from looking straight on. you gotta look from under like in front of the wheel.
: / damnit. ya its only one im pretty sure. i should go check to see how close the other one is. you think like a stealie would have a better offset to not rub? prolly try it today or tommorow.
![]() Join Date: Sep 2004
is it on oem wheels? if the spec is close to oem wheels, than you should not rub. take it to frame and alignment shop and have them to check what is bent, or just simply go under your car to measure distance of things
ill be getting an alignment probably after i smog it. Then ya, like you said hopefully they'll honestly tell me whats wrong or if anythings wrong. o and yes its on oem stock teardrop wheels.
![]() Join Date: Jan 2004
You probably bent a strut. I've seen a strut hit so hard that you could see a bow in the piston!
WTB: 13kg springs! Eibach, Stance, or Swift.
