200SX S13 stock height
Hello,
Somebody can tell me the 200SX S13 stock height for the front and for the rear; with stock suspension, stock 15" rims and stock 195/60R15 tires? (I need to set my coilover height same as the standard one) Thank you in advance Inviato dal mio D6603 utilizzando Tapatalk |
![]() Join Date: Aug 2011
I do not think you will be able to get stock ride height with coilovers. Usually the rears are too short. Try setting them at their highest first and see what gives. But that usually is at least a 40mm drop.
Also, they call it a 240sx here, the 200sx is another car ![]() Check these pictures, it does not have a measurement but you will find it easy to see. https://grassrootsmotorsports.com/pr...991-166-240sx/ |
