Old 06-30-2010, 06:21 PM   #1
240sxvaj
Trader Rating: (38)
240sxvaj is an unknown quantity at this point
Feedback Score: 38 reviews
S13 dcc help!
hey i was wondering if you guys can help me hook up the rest of my sensors on my s13 dcc. i still need the ambient sensor came off a infiniti, sunload sensor came off the early year q45 and 96 altima, and Cabin air temp sensor came off a infiniti .
i have the dcc installed but its only on full blast. i have the Blend door actuator,Blower motor speed controller, and aspirator tube installed already.
the thing im confused on is the 2 green extra wires w/ red dot i have that has no harness plug on it. both is on its own.
i have been through over 5 sites to install this thing but only one have info on stalling the ambient sensor and such but im still confused a little.
240sxvaj is offline   Reply With Quote
Old 06-30-2010, 07:22 PM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
you need to install the middle sensor in the air box mine did this too until i installed it, i forget what its called
Slip Gypsies Blog
not sure if you realize this
Old 06-30-2010, 07:29 PM   #3
240sxvaj
Trader Rating: (38)
i think thats part of the aspirator tube. i have that too. and im sure its installed already.
can you send me some pix of your set up where all the wiring was wired to?
Old 06-30-2010, 09:07 PM   #4
punxva
punxva's Avatar
Trader Rating: (31)
actually my bad its this
here's a link to the writeup i followed
#/f/tech-talk/154426...e-control.html
Slip Gypsies Blog
Old 06-30-2010, 09:30 PM   #5
240sxvaj
Trader Rating: (38)
Thanks but that was the first write up i follow and it doesnt show the extra harness i have. maybe mine is just there for some odd reason?
i will post a pix of my harness tomorrow.
Old 07-01-2010, 12:04 AM   #6
punxva
punxva's Avatar
Trader Rating: (31)
yeah do that and i will try helping you, i got mine straight out of a car in japan from my friend he cut behind the stock plug so i had both sides of the pigtails since he didn't know what i needed
Slip Gypsies Blog
Old 07-01-2010, 05:01 PM   #7
240sxvaj
Trader Rating: (38)
here is what i have and all installed already. i also got the rest of the sensors needed.
here is the pix im talking about:
The black circle in the pix is the 2 greens wires that i was telling you about and it looks like it was cut and has no harness plug when i bought it. im not sure where those wire are connected to.
The blue circle in the pix is where all the extra wires i have left. i follow the write up and switch the wire Blue/Red stripe to the harness like told now im left with the other wires.
lmk what wires are connected to the sunload sensor, ambient sensor, and cabin air temp sensor
Old 07-02-2010, 05:47 PM   #8
punxva
punxva's Avatar
Trader Rating: (31)
mine had all of the plugs on it for all of the sensors
Slip Gypsies Blog
Old 07-02-2010, 06:01 PM   #9
240sxvaj
Trader Rating: (38)
whenever you have time can you send me a pix of how your dcc is wired up to everything?
thanks!
Old 07-04-2010, 02:34 PM   #10
240sxvaj
Trader Rating: (38)
bump! anyone know the wires?
Old 07-14-2010, 10:37 AM   #11
deadghost
deadghost's Avatar
deadghost is a jewel in the roughdeadghost is a jewel in the roughdeadghost is a jewel in the roughdeadghost is a jewel in the roughdeadghost is a jewel in the roughdeadghost is a jewel in the roughdeadghost is a jewel in the roughdeadghost is a jewel in the rough
Im having the same problem, my AC unit is set to full blast, and not to mention that my night lights will not turn off on my rear tail lights, im trying to figure out if its a relay! Any thoughts?
deadghost is offline   Reply With Quote
Old 07-14-2010, 11:40 AM   #12
S13 Matt
S13 Matt is an unknown quantity at this point
The green wires are either for the sunload sensor ( the one that goes on top of the dash) or the sensor that goes in the engine bay. Its been a while since I have done mine, so I cant recall 100%.
S13 Matt is offline   Reply With Quote
Old 07-15-2010, 10:24 AM   #13
240sxvaj
Trader Rating: (38)
Originally Posted by S13 Matt View Post
The green wires are either for the sunload sensor ( the one that goes on top of the dash) or the sensor that goes in the engine bay. Its been a while since I have done mine, so I can recall 100%.
hmmmmmmm.......i thought that too but when i connected it i couldnt really tell if it was working or not. also there is 2 wires on sunload sensor and ambient sensor.
Old 07-15-2010, 10:31 AM   #14
S13 Matt
I can pull mine out this weekend and tell you for sure.
Old 07-15-2010, 10:59 AM   #15
creyes13491
creyes13491's Avatar
Trader Rating: (30)
creyes13491 is on a distinguished road
Feedback Score: 30 reviews
here, this might help with your problem.
part 1
YouTube - S13 Digital Climate Control Conversion
part 2
YouTube - S13 Digital Climate Control Conversion - Part 2
part 3
YouTube - S13 Digital Climate Control Conversion - Part 3
creyes13491 is offline   Reply With Quote
Old 07-17-2010, 08:42 AM   #16
420sxwetdreams
420sxwetdreams's Avatar
420sxwetdreams is an unknown quantity at this point
i belive someone just did a 3 part dcc install on you tube let me know I will be doing the same thing next month... GL
420sxwetdreams is offline   Reply With Quote
Old 07-17-2010, 11:30 AM   #17
240sxvaj
Trader Rating: (38)
i would love you forever if you can do this for me. and i mean every wire even though i already have them installed.
thanks!
as for the youtube clips i already seen those and the thing that sucks about it is he doesnt show what wiring goes to what, he only says it. but it was a good vid
Old 10-03-2010, 05:34 AM   #18
noynek
noynek is an unknown quantity at this point
Bump:
Hi Guys the wire color for the sunload sensor and outside ambient air sensor would be helpful for me to. I have everthing else fiigured out on a slightly cut harness
Thanks much
noynek is offline   Reply With Quote
Old 10-11-2010, 01:50 PM   #19
noynek
Originally Posted by noynek View Post
Bump:
Thanks much
BUMP
Can anyone help a brother. I cant figure out which wire on the DCC subharness connects to the outside air temperature sensor
Thanks
Old 10-13-2010, 06:15 PM   #20
240sxvaj
Trader Rating: (38)
man someone needs to do another write up on the DCC's but with 100% exact pix of EVERYTHING lol
